Go Back   Automotive Forums Car Chat > MG > MGB
Old 01-13-2005, 02:05 PM
mcapple mcapple is offline
!977 MGB Inignition Switch
I have a 1977 MGB, when I start it it runs fine until I release the ignition switch. The engine then cuts off. I can easily restart it but when I release the switch it cuts off again. Can anyone offer any suggestions? Do I need a new switch?
Thanks!
Robert
Old 01-15-2005, 01:11 PM
Flash75 Flash75 is offline
AF - Advisor
Re: !977 MGB Inignition Switch
Robert: Does the fuel punp run when the switch is in the run position? If it does the switch is probably ok. Do the windshield wipers work when the switch is in the run position. If they do you ignition relay is probably ok. With the switch in the run position check for a voltage at the + coil terminal, it should have around 6 volts. If it isn't there and the wipers don't work it's probably the ignition relay. If the wipers work and there is no voltage at the coil there is probably a wiring problem check the white/brown wiring spades at the fuse box. Insure the connection aren't corroded. I hope this information gets you started. I assume you do have a Haynes repair manual. Good luck, Clifton
Old 02-04-2005, 11:36 PM
KimMG KimMG is offline
AF - Advisor
Sounds like the electrical part of the ignition switch has failed. The switch is easy to replace. It should take less than an hour
Old 11-04-2005, 09:14 AM
jimmy wade jimmy wade is offline
ignition switch
I have a problen maybe opposite, mine won't stop.I have to keep moving the key until the INNITION light comes one. Then is a few seconds, to engine will stop. It seems to depend on how long I have bbeen driving as to how long it takes to turn off.
Old 11-04-2005, 01:45 PM
AF - Advisor
Jimmy, What year car? If it is a rubber bumper car look at the wiring diagram in Advance Auto Wire at;
http://www.advanceautowire.com/
On the left click on stock schematics,
next click on MGB, MGC, etc and find the correct wiring diagram for your car. If your car is a 76 or newer it should have a diode in a service reminder circuit and another in the handbrake circuit. I believe the 75 has the service reminder but not the handbrake diode. These diodes have been known to cause the engine to continue running when the ignition has been turned off. The temporary solution is to disconnect the circuit and see if the engine stops. If it does the diode needs replacing. You will have to find a substitute diode from Radio Shack or some electronics store.
Clifton
Old 11-05-2005, 08:05 AM
Re: Re: !977 MGB Inignition Switch
Clifton
Thank you so much. I will see what I can find. It is a 1978 model.
Old 11-06-2005, 04:17 PM
I found the two Diodes and took them out. The car still ran and still had the problem. I tried the local Radio Shack but they did not have a replacement. I think one of them is bad.
Old 11-08-2005, 06:13 PM
Problem solved! Put a diode between the alternator and the ignition light.
Old 11-09-2005, 07:26 PM
AF - Advisor
Jimmy, Thanks for letting us know what fixed the problem.
Clifton
