Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-13-2005, 01:58 PM
BOTTLEFEDCUTLASS BOTTLEFEDCUTLASS is offline
Angry Temp at 240
96 Aurora. Here's one.... The temp gage is at 240 and it's not blowing any heat! It was a half a gallon low. The temp outside at the noon hour was -5.
Old 01-13-2005, 02:20 PM
treeboy38's Avatar
treeboy38 treeboy38 is offline
Half gallon low on what?
1997 Burgandy Aurora
Old 01-13-2005, 02:22 PM
Re: Temp at 240
Antifreeze
Old 01-13-2005, 02:43 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Temp at 240
If your temp gauge reads 240, there is no heat...most likely (even though yoiu are low on coolant) the coolant mix is not correct and your cooling system is a block of ice...especially at -5
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 01-13-2005, 02:49 PM
Re: Temp at 240
I just had the wife put the car in the garage with the heat on and wait till I get home to look at it.
Old 01-14-2005, 12:04 AM
rodtice's Avatar
rodtice rodtice is offline
The reason you were hot was being low, the reason for no heat was being low. If you rev it up you may get heat. Do you have a leak, or a blow a head gasket.
Check your oil if you have no leak. If your low enough on coolant your water pump won't work, therefore no heat.
Old 01-14-2005, 12:32 PM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
Re: Temp at 240
Sounds like a blown head gasket or massive cooling system failure. Could potentially be a big problem.
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
Old 01-14-2005, 05:07 PM
Isnibs's Avatar
Isnibs Isnibs is offline
Re: Temp at 240
Or you were so low on Antifreeze that the heater core emptied.
1996 Aurora Black / grey
Old 01-15-2005, 01:42 PM
jp396 jp396 is offline
Re: Temp at 240
sounds like its frozen over.
Old 01-15-2005, 01:44 PM
robTypeR robTypeR is offline
Banned
Re: Temp at 240
u have no antifreeze ur heat wont work and i hope u no ur engin is gonna overheaet good day
Old 01-17-2005, 07:37 AM
Re: Temp at 240
Well after this weekend... The car just sits at 240 degrees. It hasn't needed any water. As for being froze. I kept it in a heated garage and it's still doing the same thing.
