Old 03-10-2002, 03:16 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Catalytic Converter
Just wondering anyone knows a good catalytic converter for a 95 civic ex. Also correct me if I am wrong, is the OEM spec for the cat a 2.5" diameter?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 03-10-2002, 06:20 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
a good cat is stock unless you have a lot of power adders that require a larger bore exhaust.
stock cat should be less than 2" diameter on a Civic
Old 03-10-2002, 10:01 PM
Tofuboy's Avatar
Sorry about the confusion, what I ment was a high flow cat, or a straight pipe. It does not necessary to passing smog test, I just want to compare which cat (passing and not passing smog test) outthere is worth to get.
PS I once saw a Y shape piping (install before cat) that allow user to bypass or not bypass the catalytic converter, does anyone has a link to that?
95 Civic EX
83 Toyota Starlet
Old 03-12-2002, 08:45 PM
Prelussion Prelussion is offline
Send a message via AIM to Prelussion
A highflow cat might help if you already have intake, headers, and exhaust, i would get those three first, then a Carsound hi flow cat. Just don't gut yours, the big open space will cause a disturbence and your will lose velocity, so get the high flow cat, or a test pipe if you don't daily drive your car much.
TDC member # fo-1-1 (411)
Official TDC hitman.
Old 03-14-2002, 04:11 PM
Tofuboy's Avatar
I just need to know which high flow cat or test pipe are good out there. Brand? Price? diameter? Thanks
95 Civic EX
83 Toyota Starlet
Old 03-16-2002, 09:55 PM
Carsound cat. Look it up on google.
Old 03-17-2002, 04:36 AM
xodus917 xodus917 is offline
will high flow cats pass smog in cali?
2000 Integra GSR
-AEM Cold Air Intake
-AEM Bypass Valve
-Apex'i N1 Exhaust
-Hyperion Coilovers
other mods ::
-Blue Valve Cover
-Clear Bumper Lights
soon to come ::
-DC Headers
-DC Short Shifter
-S2000 Antenna
Old 11-04-2004, 08:23 PM
94PROBEGTR's Avatar
94PROBEGTR 94PROBEGTR is offline
Send a message via Yahoo to 94PROBEGTR
yes it will pass. i have a PACESETTER in mine cost was $233.72
you can look around for a decent price hiflows go from $80-$300
1994 Ford Probe GT
2.5L KLDE V6 24 Valve DOHC ATX
164hp @ 5000 RPM
163,000+ miles and counting....
Old 11-12-2004, 11:09 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Catalytic Converter
at a shop close to my house (just outside of ottawa, Canada) they have some for $75 CAD.
