Old 01-13-2005, 12:42 PM
jbizel's Avatar
jbizel jbizel is offline
getting horsepower.
i was wondering what are some good ways to get lots of horspower out of the 3.8 liter? and will an oem supercharger fit on a non supoercharged grand prix??
Old 01-13-2005, 01:54 PM
carnutcass's Avatar
carnutcass carnutcass is offline
You csn get more HP out of your NA 3.8 by doing the following:
CAI or FWI
Cat back exhaust
Reprogrammed PCM
Roller rockers
Headers
Cam
MSD coil packs
Plugs
The only problem with this is that you could spend a lot of money to get moderate results. You could always add a turbo or centrifugal supercharger, but they are EXPENSIVE.
The "will an oem supercharger fit on a non supoercharged grand prix" question has been asked many times. The answer is, "Not very easily."
Old 01-13-2005, 06:15 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: getting horsepower.
Ok I'm soory for the size of this but this will tell you what you have to do for faster times.
You can look up the prices for the parts;
Performance Recipes
How fast is my L67-powered car in stock form?
We get asked this question all the time, so we’re going to give this our best shot…
If you have a ’97 to ’02 GTP or GS, your car will run about 14.8 in the quarter mile in stock form. There are lots of variables here, but this is a realistic average based on our experiences. If you have an SSEi, your car will be about one second slower. The Bonneville’s are only a few hundred pounds heavier, but they are slower for several other reasons too:
additional weight (several hundred pounds)
poor weight distribution for drag racing (things like the battery in the back seat, aluminum hood, aluminum control arms and aluminum front bumper all work to reduce the percentage of weight on the front tires, resulting in less traction during acceleration)
larger front brakes (more rotating mass reduces power put to the ground)
larger tires and wheels (increased rotating mass takes more power to accelerate)
restrictive PCM (much more aggressive traction control system cannot be overridden by simply pulling a fuse; PCM will actually retard ignition timing if you try to power-brake the car)
no Performance Shift function (so shift points are lower and shifts are slower)
no air opening behind the headlight means that removing the headlight won’t give you any cold air
The Regal GS is slightly (a couple tenths) slower than a similarly equipped GTP, for some of the same reasons as the SSEi.
There are MANY different possible paths to get you to a certain performance goal. Following are some EXAMPLES of recipes that we know work:
How can I get my GTP or GS to run in the low fourteens?
one step colder thermostat (180 degrees)
one heat range colder spark plugs (AC Delco 41-932 or Autolite 605 or NGK TR55)
cold air induction
3.40” supercharger pulley
How can I get my GTP or GS to run in the high thirteen’s?
two heat ranges colder spark plugs (AC Delco 41-919 or Autolite 104 or NGK TR6)
cold air induction
3.25” supercharger pulley
INTENSE 1.90:1 rocker arms/pushrods package
free-flowing cat-back exhaust
How can I get my GTP or GS to run in the low thirteen’s?
two steps colder thermostat (160 degrees)
cold air induction
3.10” supercharger pulley
SLP headers, downpipe and free-flowing cat-back exhaust
DHP PCM
mix of unleaded race fuel
drag radial tires
How can I get my GTP or GS to run in the high twelve’s?
three heat ranges colder spark plugs (Autolite 103)
cold air induction
ZZP throttle body
3.00” supercharger pulley
Lucas 42.5 pound/hour fuel injectors
INTENSE Stage 1 Blower cam/pushrods/rockers package
DHP PCM
INTENSE Transaxle with INTENSE Limited Slip Differential and 3.29:1 final drive
street slicks
How can I get my GTP or GS to run in the mid twelve’s?
cold air induction
ZZP throttle body
ZZP supercharger
2.80” supercharger pulley
Walbro fuel pump
ZZP intercooler
INTENSE Stage 2 cylinder heads
INTENSE Stage 2 Blower cam
DHP PCM
INTENSE Transaxle with INTENSE Limited Slip Differential and 3.69:1 final drive
street slicks
All the above numbers are GUIDELINES only, and make a few assumptions:
We assume you race at a reasonable altitude. You won’t be able to match these times if your track is 5,000 feet above sea level for example.
We assume that you race in good weather conditions. You won’t be able to match these times on a hot, humid day with low barometric pressure.
We assume that basic race preparation is done to the car. Remove the spare, empty the trunk, remove the floor mats, race with a quarter tank of fuel, set your tire pressures properly, etc.
We assume that you launch your car effectively. This is the most important part of the quarter mile race, and without a good launch, you will NOT be able to achieve your best E.T.
Old 01-14-2005, 06:04 AM
jeffs_GTP_sleeper's Avatar
jeffs_GTP_sleeper jeffs_GTP_sleeper is offline
kid he has an NA engine.
The cartuning turbo kit is $3000 but would give you alot of power.
ANother option nobody has mentioned is the $999 M90 OEM Supercharger upgrade offered by www.zzperformance.com
It is a factory GenIII M90 but comes with the necessary adjustments and pieces to adapt it to an L36 NA 3800.
