Old 01-13-2005, 11:43 AM
pp270 pp270 is offline
Wheel Beering Sensor
I also am recieving the service vehicle soon/antilock break/lowtrac light that has been well documented. My scan tool lists four codes one of which points to the wheel beering sensor, but since my Haynes manual doesn't list the descripitons for the other three codes I am not sure which of the four sensors is bad. Is there an easy way to trouble shoot these sensors? If so please explain.
Old 01-13-2005, 11:41 PM
JTrujillo86 JTrujillo86 is offline
Re: Wheel Beering Sensor
You need to replace the entire hub assembly because the speed sensor, which is what usually goes bad, is not seperate from the hub. The hub assembly and the wire harness need to be replaced.
Jeremy
Old 01-14-2005, 03:58 PM
Yes, but how do you know which sensor is bad? Is there an easy way to diagnose a wheel bearing sensor? Any ideas?
Old 01-15-2005, 09:01 AM
Question Wheel Bearing Sensor
Does any know how to determine if a wheel bearing sensor is bad via manual inspection or diagnosis without the use of a scan tool? I would like to do some repairs this weekend.
