Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 01-13-2005, 12:31 PM
acoustic's Avatar
acoustic acoustic is offline
Concorde Door Panels
hey all. i have a 97 concorde lxi, and just recently, there is some sort of rattle in the passenger side door panel. so im lookin to get in there and see if i can find out whether its the speakers or the panel itself. if anyone knows the easiest way to take it off it would be really nice to know, thanks.
dan
Old 01-13-2005, 09:04 PM
AWP9521 AWP9521 is offline
Re: Concorde Door Panels
Checking the speaker for looseness should be easy, the screen is removable to gain access to the speaker, just pry the screem off by inserting a flat blade screwdriver between the front lower corner of the screen and the panel and it should pop right off, the speaker is screwed to the panel with 2 screws. If you need to remove the whole panel then there are 2 screws in the speaker area, one or two at the armrest (possibly one of them behind the light), I think there is one under the window switch bezel, and one or two on the outside edge of the panel then it should unclip from the door. Not really sure as I never had to remove a panel, someone else may know more.
Old 01-24-2005, 07:14 PM
acoustic's Avatar
thank you AWP. ill definately give it a try.
