Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-13-2005, 09:18 AM
captdon captdon is offline
Question bronco engine swap
I have a 85 bronco II with a bad engine 2.8 carbed, I have a donor truck a 86 ranger 2.9 fuel injected. I know that physically it will set right in and bolt up to tranny. My question is how and what to change for electrical systems and fuel systems. I can use the fuel pumps and lines and wiring from the truck I think But I dont know anything about the other wiring for efi. Or wood it be easier to just use the block and put my intake and carb on it, I would really like to have the additional power of the 2,9 and fuel injection Please help Thanks, captdon.
Old 01-22-2005, 12:28 PM
Truck Truck is offline
The easiest way to keep the EFI would be to take the PCM as well. (The P.ower C.ontrol M.odule) is the brain-box- you shouldn't have too much problem, other than getting them out! (Look for the big 60-pin connector in your engine bay, driver's side-it bolts on with a small nut, but I'm not sure exactly how they come out!)
The main difference here would be the Transfer Case-if yours is Electric (from the Ranger, even) you should take it. If they are both manuals, you shouldn't have too much trouble with them.
Old 01-25-2005, 09:12 PM
Re: bronco engine swap
Thanks for the info, the ranger is a two wheel drive and the bronco is a auto trans but manual transfer case. Any other info? thanks Captdon
Old 01-26-2005, 06:32 PM
Well, you'll probably luck out, and have both Trannies in the Brain-Box. (The Box Identifies the components that are attached to it-so it can make them run properly.) Given that the two vehicles are separated by only 1 year, and are both Ford Trucks, you may be in luck. (However, if you were trying to fit that 3.8L Lincoln engine in--you see the difficulty.)
I may be wrong, and perhaps these two years are different-there's always that chance. I would doubt that, since the Ranger obviously had a 4x4 option, and it was probably very close to what is in your BII.
Old 01-28-2005, 08:46 PM
Truck, thanks again for the info I think I'm going to start the swap next week, it will take me a while in my spare time but I will make many notes and take many pictures and maybe be able to write the book on this swap and help others that want to try it, thanks again captdon
