Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-13-2005, 01:18 AM
buddman15 buddman15 is offline
Send a message via AIM to buddman15
answer and you get a cookie....
I need the cylinder head specifications for an S-series 1.9 DOHC engine. Car model and year are unknown as is the casting number. The head does have " A 266 " stamped on it and the blcok has " B 326 " and " 21000950 " on it, can anybody translate this into something relatively useful? Ok for the head specs I need: Valve Angle, Vavle Spring Installed Height, Valve Stem Diameter, Valve Guide Clearance and Valve Head Diameter. If theres any other info that would be useful hit me up and Ill try to get a hold of it. Thanks for your help.
Old 01-13-2005, 08:16 AM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
Re: answer and you get a cookie....
i think i want more than a cookie for that answer... i'll do some research for ya
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-13-2005, 08:29 AM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
What year is the vehicle?
Old 01-13-2005, 10:43 AM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
Re: Re: answer and you get a cookie....
Yeah, a cookie isn't going to recoop the cost of that Saturn mechanic's manual...
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Old 01-13-2005, 12:01 PM
Hah, yea I know this isn't the easiest information to obtain. I'm rebuilding this engine for a class and it's required to know these specs. Everyones help is greatly appreciated. and no sorry, but no I dont know the year of the car it came from.
Old 01-13-2005, 12:09 PM
what does the cam cover look like? is it aluminum or composite?
Old 01-13-2005, 01:04 PM
Looks to be aluminum
Old 01-13-2005, 06:24 PM
ok so its an earlier model 91-97 probably... i think they changed it in 98. someone correct me if i'm wrong but that should help on finding the specs... that takes out at least 5 years...
Old 01-13-2005, 06:28 PM
Thanks carguy83!! Thats a pretty big step in finding out what I need to know. Can anybody find the head specs for this engine?
Old 01-13-2005, 06:32 PM
have you thought about calling a saturn dealership?
Old 01-14-2005, 12:44 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
IF it is the alumium valve cover, then its 91-95. to confirm this, there should be two coolent temp sensors by the upper radiator hose. the engine in this pic only has one, under the EGR, the second sensor would be above the first sensor.
specs according to haynes repair manual(for 91-97/98 DOHC, depending on spec):
Valve Face Angle- 44.5 - 45.5 degrees
Valve Spring Free Length- 1.61 In
Vavle Spring Pressure- 163-180Lb (157lb service limit) @ 0.984 In; 66-77Lb (63lb service limit) @ 1.34 In
Valve Stem Diameter- Intake - 0.2736-0.274in(0.273 service limit); exhaust - 0.2726-0.2736in (0.272 service limit)
Valve Stem to Guide Clearance- Intake - 0.001-0.0025in(0.004 service limit); exhaust - 0.0015-0.0032in(0.005 service limit)
Valve Margin width- Intake - 0.0378-0.0496in(0.035 service limit); exhaust - 0.0441-0.0559in (0.039 service limit)
Valve Seat width- Intake - 0.0394-0.0512in(0.0653 service limit); exhaust - 0.0512-0.0630in (0.0756 service limit)
Old 01-14-2005, 06:47 AM
mmmm thats yummy knowledge
Old 01-14-2005, 11:58 AM
Wow, sierrap615 you're my hero, and yes, it is the 91-95. I cant thank you enough, thanks for your hard work. You guys kick ass. Now about that cookie......
Old 01-14-2005, 12:07 PM
mmm if only i had gotten to my manual first... and if only i had thought to goto it...
