Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 01-13-2005, 12:08 AM
jpeezey jpeezey is offline
oil pressure probs
i have a 92 sonoma i bought as a project truck. the motor has recently been rebuilt but the oil pressure drops as it warms up. After about 10 minutes its almost on the redline. i've already replaced the sending unit, and oil pump, added a mechanical gauge in addition to the factory gauge, went to a thicker oil, retorqued all the bearing caps, and im still having no luck with this. what else is there to do to fix it or should i just ignore it? it doesnt knock and as soon as i hit the gas, the pressure goes back up but this is drivin me up a wall. how do i make it stop acting up?
Old 02-01-2005, 02:15 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: oil pressure probs
The maual gauge is reading no pressure either?
What type of oil filter are you using?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-10-2005, 11:21 PM
yeah. the manual gauge shows 0 maybe 1 lb of pressure and the factory gauge completely bottoms out and the check engine light comes on. it dont do it till it gets warm tho. and its a fram oil filter.
Old 02-11-2005, 09:22 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
If both the manual and the dash gauge are showing that and you've replaced the oil sender, more than likely 1 of your lifters has collapse, pull and inspect. They will not always tick if one is bad... A completely collapsed lifter will not tick at all.
Old 02-11-2005, 02:17 PM
BlazerLT's Avatar
AF -Advisor
good point, a loss of pressure this bad means no restriction in the system, or the oil pump is shot.
