Old 01-12-2005, 11:52 PM
cavispeedracer cavispeedracer is offline
Send a message via AIM to cavispeedracer
low RPM at stop
when my cavi is stopped the RPM's go up and down slightly, not below .5 but not above 1 - it sounds almost as if it will stall or die out - any ideas?
1996 Camaro RS
1997 Cavalier Z24 Modified
1/4 mile 15.5 at 89mph
FOR SALE!
Old 01-12-2005, 11:53 PM
igor@af's Avatar
igor@af igor@af is offline
Your friendly AF Admin
Send a message via ICQ to igor@af Send a message via AIM to igor@af
Re: low RPM at stop
That is what the idling RPM should be. Or does it make odd sounds?
Welcome to the Revolution
Old 01-13-2005, 09:36 PM
gonzales7727's Avatar
gonzales7727 gonzales7727 is offline
Re: low RPM at stop
vacume hose or line what ever U want to call it
Old 01-13-2005, 11:55 PM
the car just shakes sometimes almost like it wants to stall out and the RPMS go crazy up and down...... what is the vacuum hose?
1996 Camaro RS
FOR SALE!
Old 01-14-2005, 12:15 AM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: low RPM at stop
yes sounds like a vacume hose - it is rubber hose that runs vacume pressure - in your case sounds like it could be a vacume leak - maybe a cracked hose or just fell off - just some suggestions - check the lines goin to the TB - you can pick a vacume tester pump at the parts stor for like 30 - 40 bucks - there is instructions on the package on how to use it or if its a Advanced Auto the clerk will show u how to use it in the parking lot
