Old 01-12-2005, 11:37 PM
Mindyj Mindyj is offline
93 Chevy Z71 350 warm start problem
I have a 93 Chevy Silverado with a 350. Recently something happened with the starter and blew the positive battery cable completely apart up by the terminal. We put a new starter in, positive cable, and battery and everything was fine for about a month. Now it starts when it's cold but after it's warm it turns over once, clicks and then nothing. But after it cools, starts up. We thought it was the starter again so put another one in, but still the same thing. All the connections are good. Do you have any idea what could be wrong?
Old 01-13-2005, 07:50 PM
planedude planedude is offline
Re: 93 Chevy Z71 350 warm start problem
check your main ground wire to the engine block. also did u put the heat sheild back on your new starter?
Old 01-13-2005, 08:31 PM
already checked the ground wire, but didn't put the heat shield back on, is that a problem?
Old 01-14-2005, 11:23 PM
rabt's Avatar
rabt rabt is offline
yep ... if the starter solenoid switch gets hot it will not engage the starter
Old 01-15-2005, 12:57 PM
like rabt said the sheild is important, I left mine off and it was doin the same thing. Heatsoaking and starters don't go well together.
Old 01-15-2005, 07:38 PM
Took the ground wire off the block and cleaned it again. Put it back on and having no problems, I think it is a temporary fix though, so we will get the heat sheild back on too. Thanks
