Old 01-12-2005, 11:25 PM
xyfalconsrock's Avatar
xyfalconsrock xyfalconsrock is offline
Send a message via MSN to xyfalconsrock
Unhappy Revell model defect
As you can see by this photo the model I have just bought is defected. I was wondering if someone could direct me as to a way to fix it. Or is returning the model the best way to go?
All help is appretiated.
Old 01-12-2005, 11:29 PM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
Re: Revell model defect
heat it up just enough 2 bend it back perfect i guess.
Project Lexus Revive
Old 01-12-2005, 11:34 PM
Jaymes's Avatar
Jaymes Jaymes is offline
looks like it must have been crushed while stored. One of my biggest fears when stashing models in the closet =O
Old 01-12-2005, 11:41 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
No need to take it bak. If it's just the A-piller, no need to even heat it. Just carefully apply pressure on the part until it's flexed a tiny bit past where it should be, then let it go. It should return to its correct shape after doing this just a couple times.
Old 01-13-2005, 12:44 AM
I think i might just take it back because I don't want to damage it further. I take it back and get the really cool camaro they ahd in there for the same price.
Old 01-14-2005, 02:44 AM
Purpura Delujo Purpura Delujo is offline
Mate, just pinch it with you fingers and slowly move the A pillar back in, easy. I've had kits with far worse damage then that! try a 1959 Impala convertile that was so warped it took 30 mins of hot water soaking to get it to bend back, I had to repeat that process 3 times.
Old 01-14-2005, 05:30 AM
cyclone1410's Avatar
cyclone1410 cyclone1410 is offline
Honda Convert
Re: Re: Revell model defect
He's right. Just bend it back to correct position. If it won't stay there use the hot water method (run it under hot water, bend it back to the correct position and while holding it run it under cold water). It is surprisingly difficult to stuff it up.
Old 01-15-2005, 04:07 AM
mike united's Avatar
mike united mike united is offline
I had a similar problem with a Revell Mercedes 600 S, i wrote to them (link below) explaining the matter & they sent me new body parts & i didnt even have to return the damaged body.
http://www.revell-monogram.com/broken/
Its up to you but you could always give it a whirl !!!
Mike
Old 01-15-2005, 06:38 AM
I'm going to replace this model(1999 Mustang cobra) with a 1971 chevy camaro which I saw at the same shop. Because I bought two mustangs at the same time from there, so I'm lucky I have a reason to change it over.
