Old 01-12-2005, 11:13 PM
mtb020184 mtb020184 is offline
Send a message via AIM to mtb020184 Send a message via Yahoo to mtb020184
Acceleration Problems
Well my 89 IROC-Z (305 tbi throttle body) is still accelerating like crap, and the air cleaner is soaked in gas. I originally changed the air filter, and fuel filter for the acceleration problem, but it still didn’t go away. I just pulled the cat. converter off tonight, and it looks clean to me, I can see through the mesh.
Any Ideas???
Old 01-12-2005, 11:23 PM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
My Idea.. get a Nova!!
Seriously though, it sounds like something to do with the spark. Check all your plugs and wires. Whats your timing set at? I would check all things having to do with spark, then go from there. Is the car spitting out any codes? Check all these things, then we can help you better.
Rob
Old 01-12-2005, 11:43 PM
Besides the few problems the car is running fine. I will try to check for codes tomorrow. Its kind of slow going working in the car because it is buried in the corner of out barn for the winter, and sometimes its just to hard to go work on it when its 20 degrees out
The only code I got out it is 12, which as far as I know is the code that just shows that the test circuit is working
Old 01-13-2005, 07:05 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: Acceleration Problems
sounds like a stopped up fuel injector. may not be stopped up bad but enuff to squirt the fuel up on the air filter. i see your point about the crappy weather there. does the car set during the winter? i let mine set all winter. which i started it twice a week and let it run 25 minutes a time, and still i had to take out the plugs, clean them up, and put some injector cleaner in.
Old 02-07-2005, 01:47 AM
[email protected] jldeising@citcom.n is offline
Any Ideas???
Check your timming chain slack (by lining up timing mark at TDC and moving the crank untill the dist. starts to move. Then turn the crank the other way unill the dist. starts to move. Note how many degrees on the timing marks it took for the dist. to move from either direction. Rule of thumb: no more than 9 degrees.
Do a compression test.
Sometimes a leaking intake valve/s will allow the fuel air mixture to be pushed back up through the intake saturating the air cleaner.
This would also contribute to the lack of power.
