Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-12-2005, 11:17 PM
fab08 fab08 is offline
Unhappy 99 Camry, shuts off when cold, as soon as its warm then its fine.
Hi,
I have a 1999 Toyota Camry 4Cyl, when I start it and its cold it will shut off right away, it wont stay on unless I keep the steping on the gas untill its warm, once warm then its fine, and will start again and stay on without any probles....
Any one has an idea of what this could be?
At the auto store, someone sugested cleaning the throtle positioning sensor, another person told me to replace the temperature sensor.
Any ideas?
Any help greatly appreciated!!!
Old 01-12-2005, 11:32 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 99 Camry, shuts off when cold, as soon as its warm then its fine.
Coolant temperature sensor is possibly bad.
Check distributor cap, rotor, etc replace if questionable.
Old 01-13-2005, 02:03 AM
stephiemullen stephiemullen is offline
When my dad's was doing that it needed an idle speed control motor. It was doing the exact same thing. Yet again, when my boyfriend's did that his engine ended up blowing up. Be careful with those Camrys.
Old 01-13-2005, 10:50 AM
burchard burchard is offline
Re: Re: 99 Camry, shuts off when cold, as soon as its warm then its fine.
If you car was a 92-96 camry I would say that's is and Air Intake Control problem. I thinks it has to do with the idle speed control however, I have no knowledeg about the AIC in 98's.
Old 01-13-2005, 06:34 PM
Joe W Joe W is offline
Has the check engine light come on at all? If it has, you can get the codes from the computer read at Autozone or some other such place. This should point you in the right direction.
Old 01-18-2005, 02:15 PM
eastwoodgeek eastwoodgeek is offline
97 Camry LE
I'm having the same issue. I bought the Camry LE 4 cyl, 4 months ago, used (77K miles) and it's got the same cold start issue. It's gotten worse as the temps have dropped here (S.E. PA). Several other forums mentioned using throttle body cleaner to get rid of any buildup. I'm going to give that a shot this weekend and see how it works. It's supposed to be in the teens the rest of the week, so it'll be a good test. Thx for the input, folks.......Go Eagles!
geek
http://www.eastwood.com
Old 01-18-2005, 03:10 PM
Re: 97 Camry LE
geek
Check this
http://www.automotiveforums.com/vbul....php?p=2689673
Old 01-18-2005, 03:43 PM
Thanks.
I also found similar advice at
http://www.toyotanation.com/forum/t27066.html
The fix doesn't sound too tough. I appreciate all the help. I like keeping these Toyotas running. I just retired an 85 Corolla w/267K miles. It's too cold to mess with it right now, and Mom needs a car to drive. Maybe this spring I'll replace the 4ALC.
Geek
