Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-12-2005, 10:03 PM
catbee catbee is offline
Angry 03 hemi temp gauge rising, not heat
03 ram hemi temp gauge will rise as heat shuts off blowing cold air.....coolant is overflowing through overflow tube....whats causing this?
Old 01-12-2005, 10:37 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 03 hemi temp gauge rising, not heat
It's pressurizing somewhere.
My Mopars
Old 01-13-2005, 11:37 AM
thanks bleeddodge....they just changed thermostat and pressurized....give me a possible example if you could
Old 01-13-2005, 03:18 PM
BleedDodge's Avatar
Maybe the new thermostat was put in backwards? Did you replace it before or after this problem started?
Why would the thermostat need to be replaced on a 2003 truck? Did something else happen?
My Mopars
Old 01-13-2005, 08:27 PM
maybe backwards...i brought it back tonight...waiting for result tomorrw....nothing happend b4.....could be headgasket?...your thoughts?....thanks man
Old 01-14-2005, 11:35 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
You could also have some air locked in/near the heater core. If the problem persists once you get it back, try parking with the front end uphill to let any air out; let the thermostat cycle a couple times and keep an eye on the radiator level. If there's air you'll probably see some big bubbles come out, and the radiator level go down.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
