Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-12-2005, 06:41 PM
kourtneya's Avatar
kourtneya kourtneya is offline
prelude ignition timing
i just baught a 94 prelude. my boyfriend said the ignition timing need to be adjusted. he doesnt know where to find the service connector for the jumper wire. can someone tell the location.
Old 01-20-2005, 10:56 PM
lilwhitelude lilwhitelude is offline
Send a message via AIM to lilwhitelude
Get a timing light
If you haven't done this already, The place you are looking for is right beside your gas peddel. Check about 4 inches right of your right gas peddel behind the console. you will see 3 types of connecters. Do NOT mess with the yellow one. That is your air bag, and you don't want that going off in your face. That could hurt. The other two connecters should be should be blue and black. I don't remember which on for sure, but on has 3 wires and the other has 2 wires. The one that you install the jumper in is the on with 2 wires, the 3 wire connecter is your service port connecter to hook a scanner up to. Hope this helps.
lilwhitelude
Old 01-22-2005, 07:31 PM
kourtneya's Avatar
Re: Get a timing light
lilwhitelude
Thanks for the info. My boyfriend found the jumper connector and adjusted the timing. He is now trying to replace the timing belt but hes having problem removing the crankshaft pulley. Do you know an easy way to take it off?
Old 01-28-2005, 07:09 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
Re: Re: Get a timing light
heat up the bolt with a torch, then use a breaker bar to unscrew the bolt.
after a hundred thousand miles or so, the rotation of the crank pulley against the threading of the bolt tends to tighten it up to the point of nearly fusing.
Old 01-30-2005, 01:46 AM
Use 3/4in impact wrench if you can get your hands on one. I have a 3/4 in impact just for the honda crank pulleys. Honda puts Locktite on their crank pulleys. I have tried using a torch and it never worked for me. Maybe you'll have better luck, but an 3/4 inch impact is the best solution.
If you use a torch be careful not to heat the bolt or melt anything. I wish that I could be a little more helpful on this one.
lilwhitelude
Old 02-02-2005, 02:39 PM
kourtneya's Avatar
Re: Re: Re: Get a timing light
lilwhitelude
Thanks for the info, my boyfriend did not like the idea of using torch. He said, it could damage the crankshaft seals.
I will try to get a 3/4 impact wrench, they are available at sears. So do I need to have a big air compressor for 3/4 impact wrench? Thanks for the help again.
Old 03-04-2005, 12:04 AM
car_boy_16 car_boy_16 is offline
Re: Re: Re: Re: Re: Get a timing light
Originally Posted by xconda
Are you a dude?
HAhahaa.......That made me laugh outloud.....
I doubt she (he?) is a guy....but the "person" isn't car-dumb...
Old 04-14-2005, 07:15 PM
lucentinjection's Avatar
lucentinjection lucentinjection is offline
Send a message via AIM to lucentinjection Send a message via MSN to lucentinjection
Re: prelude ignition timing
I used an IR impart...1500 lb/ft of torque i reverse...and its 1/2 inch....IR makes i think the best impacts...way better and cheaper than snap-on's stuff
Old 07-30-2005, 11:18 AM
xconda xconda is offline
Banned
So are you a dude?
Old 10-21-2005, 12:43 AM
preview preview is offline
lilwhitelude
i still couldnt find the 3 types connectoer and i dont see any yellow wire you were saying. can you explain this again? i also need to adjust my ignition timer. thanks
Old 01-02-2006, 05:12 AM
lilwhitelude
i finally found the connectors. and i adjusted my ignition timer yesterday
Old 01-02-2006, 09:39 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Dude, this thread is OLD. Check thread dates before posting.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 01-03-2006, 05:00 AM
Re: Re: prelude ignition timing
not really old....
it just took me several months to figure out how to set my ignition timer. and i just want to thanks to the dude who provided the informations.
Old 01-04-2006, 07:33 PM
Re: Re: Re: prelude ignition timing
Originally Posted by preview
not really old....
/nope too bad. this thread is OLD.
dSoc member #67
Old 01-05-2006, 12:49 AM
lllhayabusalll lllhayabusalll is offline
how did you adjust the timing? i need to check mine cus some mechanic said my timing is off.
