Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 01-12-2005, 04:49 PM
expe1969 expe1969 is offline
Unhappy 1999 Expedition AWD - problem
Wow, we are having a bad start to '05.
My wife drove away this morning and the AWD is aparently stuck in LOW RANGE, as indicated on the dash. I drove the truck and it is clearly driving in 4 Wheel Low.
I didn't touch the switch, and I never use it in 4 wheel low.
Not sure what the fix is? The switch is in the AWD position.
I need to have it towed unless there is an over-ride function to
get it back to AWD.
Thanks for any insight.
-expe1969
Old 01-13-2005, 03:26 PM
kevinmurr kevinmurr is offline
Re: 1999 Expedition AWD - problem
I kinda have the same problem if you read thread 4x4 and speedometer problems youl see Im stuck in 4x4 low also. If I find out whats up I'll let you know please do the same. Mine is a 2000
Old 02-01-2005, 09:14 AM
Rudytech7 Rudytech7 is offline
I had this same problem, right after I bought my used Expedition. It was still under the 36K mile warranty. They determined that the front axle speed sensor was bad. It sensed that the rear tires were slipping. After replacing the sensor 3x's it was finally fixed.
