Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-12-2005, 01:52 PM
ksnider0529 ksnider0529 is offline
Send a message via AIM to ksnider0529 Send a message via MSN to ksnider0529
Unhappy 2000 GMC Jimmy-A/C, Heat and Defrost don't work!!!
I have a 2000 Jimmy and out of the blue the entire panel that holds my A/C, heat, defrost and temp gages don't work! What's weird is everything else in the car works (except the gas gage but that's happened in 3 out of four of the Jimmy's that my family owned). My radio above the panel works, and I tried the cigarette lighter under the panel and that works too. HELP! Service shops want to charge me $100 to look at it.
I've also tried all the fuses and all are in working order. Does anyone have any ideas as to what it could be? I don't want to spend hundreds of dollars just for a diagnosis! If anyone else has had this problem, please let me know! Thank you!
Old 01-12-2005, 04:10 PM
96JimmySLE 96JimmySLE is offline
Re: 2000 GMC Jimmy-A/C, Heat and Defrost don't work!!!
Do you have any air flow from any of the normal aresa i.e. defrost, floor, vents? If you do, it sounds like a vacume problem. Vacume from the engine controls the selector on what and where the air flow is directed. Hope this helps. Check the vacume lines under the hood.
Old 01-23-2005, 07:45 AM
barlow1952 barlow1952 is offline
look into the main fuse box under the hood check the heater relay may be blown
