Injector help
Ive been geting fule cut (yes i have a afc fixed it witht he wideban. got rid of the lean and richness all the way) so i beleive its the injectors... so i was looking in to buying some 450cc injectors but i dont know what type to buy... high throttle or low throttle ext... so what is recomended?
![]() Upgrades... To many to list...
if your boosting more than 14lbs, you should be hitting fuel cut on stock injectors, because thats all they are able to flow
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: Injector help
yeah its around 16 lbs... what kind of injectors you sujest? 450cc? what do you run in your car?
Re: Injector help
don't go past 14.5
if it still does it, then your in the same boat as me might be the spark plugs, might be the type of b/c, hell i still don't know, but i'll be checking to see if spark plugs is the reason soon
Re: Injector help
fuel cut is violent, the car dies and you drift to the side of the road feeling like you just blew your engine up...
spark blowout is more of a hesitation, you speed up, hesitate, slow down, speed up...kind of like a back and forth thing...your car doesn't die and it isn't violent at all... I honestly have no idea about the difference between high throttle and low throttle 450ccs...just get the ones from a dsm...you can find them pretty cheap..if not, i'm sure 3sx or dynamicracing or ipo would have them. Only thing is, are you planning on more mods, because 450ccs might end up being too small again, if you swap turbos.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Injector help
When you hit fuel cut your car does not die. to go above 15-16 psi you will need bigger injectors. Fuel cut is controlled by the air flowing in the MAS. So you could also get an aftermarket FPR and up the presure and then add more correction on your AFC. However, the easyest way is to get bigger injectors.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
Re: Injector help
yeah fuel cut doesnt always cause your car to die... me it seams as if the cars shuts off for a slpit second... i have a wideban and a sacf i tried to eleminate the cut it just wont... i have my car pretty well stoich... its not rich or lean. I just changed my spark plugs... running coppers so the spark is hot enough to ignite. the boost controller mabey im useing a greddy profect b spec 2... and i dont care about buying 450cc now and haveing to get bigger later... injuectors are cheap and i could sell them for half price... i just want my car running good now...
Re: Injector help
You will have to get bigger injetors to eliminate fuel cut.
Re: Re: Injector help
Re: Injector help
Or have them cleaned and flow tested to make sure they flow the same amount.
