Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-12-2005, 12:17 PM
zgermans zgermans is offline
Change Manual Trans. Fluid...
does anyone have or know of a detailed description on how to change the manual transmission fluid, tools needed, and type of fluid...i ave a 94 integra ls...
Old 01-12-2005, 03:00 PM
Bilson8tor's Avatar
Bilson8tor Bilson8tor is offline
Send a message via AIM to Bilson8tor
Re: Change Manual Trans. Fluid...
its pretty easy, go to a hona/acura dealer to get the recommended manual tranny fluid then go to a auto parts store and get a trannt fluid change kit, it should just be a funnel with a hose on the end and maybe new washers. then warm the car up to operating temp,turn it off, then raise up the car(its a good idea to use jack stands). get a bucket/container of some sorts for the old fluid and go under the car with, the drain bolt used a socket wrench with no socket on the end(you should be able to tell which bolt by that last bit, its on the right side if you laying down with your feet facing the front of the car). remove the bolt and allow the fluid to drain into a container. i would also suggest going in the car with the plug still out and putting in all of the gears. once all drained, put the drain plug back(with new washer if you have it) then find the fill plug which is a little about the drain plug (takes a 19mm socket i think). once you get that out pop the hood and feed the hose with the funnel down near the fill hole and go back under to stick the hose in the hole. then go back up top and begin to pour the new tranny fluid in (i think it takes a bit over 2 quarts). once you know it getting close start to pour slowly and check under for when it starts to drip. then go back under with fill plug and new washer and put it back in. start the car back up, let it idle for a while, make sure the plugs are back and you actually filled the tranny with fluid. then test drive it.
91 Civic CX - Sold
94 Accord EX - Sold
94 Integra LS - Cleaning it up
Old 01-12-2005, 03:03 PM
Bilson8tor's Avatar
if that doesnt make sense, i can take pictures later or something...
91 Civic CX - Sold
94 Accord EX - Sold
Old 01-12-2005, 03:11 PM
i think that sounds good...thanks for the feedback...
Old 01-12-2005, 11:44 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
his something interesting. u can also use motor oil if u don't want to spend the 5-6 bucks a bottle for honda's mtf, they both work the same. go to any auto parts store and ask for mtf, they will look it up in their comp or whatever and it will point them to motor oil.
Old 01-13-2005, 01:23 PM
thanks again all...i changed the fluid last night...it was pretty easy...i bought the 3qts. of honda mtf for $12...changing the fluid really made a difference...it goes into gear a lot easier, quieter, and smoother...thanks...
Old 01-13-2005, 06:38 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: Change Manual Trans. Fluid...
Remember you need to do it every 30K miles.
Old 03-02-2005, 07:48 PM
95RSV's Avatar
95RSV 95RSV is offline
I guess "Mobil 1 tri-synthetic 10w30" should do it for my LS tranny.
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Tokico HP Suspension
ADR DV8 Sandblack Rims
Nankang NS-1 Rubber
Old 03-02-2005, 07:58 PM
whtteg's Avatar
Re: Re: Re: Change Manual Trans. Fluid...
Not really, synthetic is a bad choice for the tranny. I personaly always just use the honda MTF but you can use any 10W-30 or 10W-40 mineral base oil.
Old 03-02-2005, 08:14 PM
95RSV's Avatar
Re: Re: Re: Re: Change Manual Trans. Fluid...
Thanks, I'll just go with the recommended honda MTF to be safe.
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Nankang NS-1 Rubber
Old 03-03-2005, 02:18 AM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
manual transmission "fluid" is not like auto tranny fluid its just gear oil you dont really need to change it. automatics need their trannies flushed, manuals dont. why do you want to change it? just change it when u get ur clutch redone or somethin
Old 03-03-2005, 01:26 PM
whtteg's Avatar
The MTF that is in our manual trannies is just like motor oil. It needs to be changed every 30k miles at the most, more often if you race amy decent amount or drive the car hard a lot. The trannies build up a lot of heat and they have no means of cooling, so that heat breaks down the oil/MTF. If you don't want tranny problems then change it every 30k or sooner.
Old 03-03-2005, 04:05 PM
95RSV's Avatar
I bought my car used and I already drove over 25000 miles. I think the fluids are way overdue and plus my shifting is not smooth so maybe a flush and change would help.
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Nankang NS-1 Rubber
Old 03-03-2005, 10:14 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
I have tried many kinds of fluid in my tranny, first i tried mobil 1 10W30...that was a bad desicion. You could feel everything going on in the tranny through the shifter. Next i tried GM syncromesh with friction modifier....Pretty smooth. I then put Regular Honda MTF fluid back in (why not when its free) The Honda stuff compared to the GM stuff is not too much different, I did notice that the GM allowed me to shift into reverse alot easier and from 2nd to 1st. just my
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 03-04-2005, 02:37 PM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
10w30???... everytime ive seen man. tranny fluid its been really thick. i would think 10w30 would be way too thin...
