Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 01-12-2005, 01:09 PM
cats cats is offline
Unhappy 2001 Sebring Sedan Water Leak
I have read many postings about the water leaks for the Sebring convertible but not for the sedan or coupe. Well, have no fear, I have a water leak in my sedan. After great investigation by the dealer they have finally found it. The windshield is the culprit! I have also read that Chrysler has had a problem with water leaking in older vehicles, prior to 2000. I would have thought they would have stopped in by now or at least enough compaints would have prompted them to correct the situation. I plan on filing a complaint with Chrsylser about this and see if I can recoup at least a portion of the $330 that it has cost me. I have been told water leaks are not covered by the extended warranty.
Has anyone else had this problem with the newer cars and what did they do for you? Any feed back is appreciated.
Old 01-06-2006, 11:27 AM
KrisLizBeth KrisLizBeth is offline
Re: 2001 Sebring Sedan Water Leak
I HAVE A HUGE WATER LEAK IN MY 2001 SEBRING SEDAN ALSO - EVERYTIME IT RAINS THE ENTIRE PASS SIDE FILLS UP IN NO TIME...IT HAS TO BE COMING FROM THE FRONT BECAUSE WE PULLED THE CARPET BACK IN FRONT AND IT WAS SOAKED ALL THE WAY UP TILL WE COULDNT REACH ANYMORE. IT POOLS UNDER THE SEAT AND IN THE BACK - WE HAVE NO IDEA WHERE IT COULD COME FROM YOU SAID THE WINSHIELD, EXPLAIN WHERE SO I CAN SEE IF THATS IT! I DONT WANT TO SPEND ALL THE MONEY TO HAVE A DEALER FIND IT I ODNT HAVE THAT KIND OF MONEY ON HAND...PLEASE HELP THE CAR ONLY HAS 27,000 MILES ON IT AND I HATE TO GET RID OF IT FOR SOMETHING LIKE THAT, ALTHOUGH I DO HAVE TO REPLACE THE CARPET IT SMELLS LIKE A SWAMP!
Old 01-06-2006, 12:22 PM
Re: Re: 2001 Sebring Sedan Water Leak
KrisLizBeth,
the leak was on the passenger side of the windshield, at the bottom. they had to reseal it and so far, no water. They actually took the door panels, and dash out to find the leak. Of course, that meant putting a hose to it so they could find the leak. I used a shopvac to get most of the water out and uses a hair dryer also. They may have to remove the complete windshield and reseal the whole thing. But the resealing of the windshield definitely worked. Hope this helps.
Old 01-09-2006, 07:42 AM
Re: Re: Re: 2001 Sebring Sedan Water Leak
KrisLizBeth,
thank you so much you are the first person ive found that has the same problem, usualy its in the conv. anyways i will try and find out if this is the problem on my own hopefully it isand i will not have to go through the dealer. i will let you know if everything works out! thank you
Old 05-20-2009, 12:02 PM
01sonsebring 01sonsebring is offline
Angry Re: 2001 Sebring Sedan Water Leak
I am probably too late to help you guys, but here goes.... i own a 2001 chrysler sebring lxi sedan. I jusd drained the water out of the rear passenger door today 5/20. it bugged me for days to hear the sloshing an not know where it came from until i saw the drips from the back door. the rubber lining at the bottom can be moved or removed and allow the water to drain quicker. I dont know for sure but I feel on heavy rains, the water simply runs down the window into the door panel. As for the wet carpet, I have had that situation since I bought the car used in 2005. In my case, the water only wets the carpet when i drive on wet roads. when it rains, i check the carpet before driving, and it's dry. If i drive long enough, the carpet becomes wet. It is a growing problem; seems to come behind the front passenger fender flap. One time I tried the bootleg and removed the fender to place plastic behind the rubber fender guard. It actually trapped the water more. It is a bad design, and I am not surprised Chrysler is in trouble; all the ac/ blower / engine problems have been there since 1998 or longer, and I still see 2005 models with the same problems as my 01.
