Old 01-12-2005, 10:35 AM
CaVy329 CaVy329 is offline
coilovers
I was wondering if i bought coilovers for my 99 cavy if I would need new shocks or if I could just use the springs or what should I do. What would be best, for a reasonable price?
Old 01-12-2005, 12:44 PM
bigdaveangell bigdaveangell is offline
Re: coilovers
I would recomend getting new struts that are meant for lowering. I would really recomend a ground control and koni red combo. Just dont get cheap ebay or dropzone coils
Old 01-12-2005, 03:02 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: coilovers
^^ Good info.. Basically it works like this. If you mount any aftermarket spring or coilover on a stock OEM strut or replacement that has a drop below 1.5" they will blow in a matter of time. KYB's struts are under warrenty uptill a drop of 1.5". You can buy coilover buy do not go past that and yes they have ways to test them and find out if they were rode on at that level. Also another thing to consider is the optimum level of peformance is obtained is when the A-arm is parrel to the ground which occurs at 1.4" lower on a j-body. Eibach has a line of springs called the pro-kit which the drop is 1.4 " .. But if you want coil over i must suggest you get either the Prostreet or Ground Control
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-12-2005, 03:04 PM
Lifted GMT-360!
Re: coilovers
Also check out the sticky on how to lower your car the right way. That has alot of useful information and can almost answer any question you have concerning suspension... if not post back and we'll try to help you out.
Old 01-12-2005, 04:20 PM
Re: coilovers
Ive got the bilstein full coilover and I would really recomend those or the rksport prostreet if you want to spend the money. I think its the best you can buy right now. I think tein just released their coilover for the jbody
Old 02-25-2005, 05:12 PM
GotZ24 GotZ24 is offline
crj, are you saying that as long as you don't drop more than 1.5", you can stick with the factory struts?
Old 02-26-2005, 12:03 AM
big dude1 big dude1 is offline
thats how i interpret it...
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp
2001 Z24 cavi, and it owns
Old 02-26-2005, 12:32 AM
Lifted GMT-360!
Re: coilovers
you can but its not a good idea. Over time you will wear them out.
Old 02-26-2005, 12:36 AM
ya, gm struts are notorious for going out in normal ride heights... definitely get aftermarket
Old 02-26-2005, 12:41 AM
Lifted GMT-360!
Re: coilovers
coil overs are a really high spring rate. So thus you want a strut that has a higher valving so when the spring snaps back there is enough force wanting to go both different ways it makes the ride feel smooth. Best struts out there for coil overs are KONI or Tein D-spec or if you get a combo of like ground control and koni, or w/e
Old 02-26-2005, 10:24 PM
noshun's Avatar
noshun noshun is offline
Re: coilovers
struts and shock are 'dampers' basically the 'dampen' the springs movement and if you lower the car the spring rate will always increase and the dampers will have to follow suit or your dampers wont work efectivel resulting in a dangerously bouncy ride! Defeintley do the strus and the strut mounts idealy as they'll be under more stress from a the higher spring rate 'shocking' them!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
