Go Back   Automotive Forums Car Chat > Buick > Century
Old 01-12-2005, 08:45 AM
jwichman jwichman is offline
2000 Century Oxygen sensor(s)
Service Engine Soon light came on the other day, had the codes checked which revealed "bank 1 oxygen sensor" code had been set. Cleared the code and it has not returned yet. I am wondering if there are more than one O2 sensors on the 3100 engine, bank 1 and bank 2 or a manual described an upstream and a downstream oxygen sensor. If there are more than one how is one differentiated from the other?
A service tech told me that they sometimes will take a faulty O2 sensor out, heat it up with a torch, and then replace it. What does heating the sensor do? Does it rejenerate something that provides additional life or does it just cook the sensor to the point it will no longer set a code?
Old 01-15-2005, 05:39 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Yes there are 2, one upstream is located in the rear exhaust manifold and the other downstream is located behind the catylic converter.The bank 1 O2 is an AC-Delco AFS-109 and there is a guy from time to time that sells them new on Ebay for about 35 bucks ,which is a great deal...do not use Bosch as they are problems ONLY USE AC-DELCO You will also need an O2 socket to remove and install .
www.ebay.com
~Larry~
ClubGP Member 6530
Since 2001
