door hinges
I need to know if anyone has had a problem with their door hinges sagging. how can i get rid of this and how much is it to replace them?
Re: door hinges
There are brass bushings that hold the door pins tight. Most likely these are old and worn. You can go to the local auto parts store (I go to NAPA) and get some news ones pretty cheap.
You will have to get the pins out, which could be tricky then pop out the new bushings and replace with the new bushings and new pins. Be careful with the door spring !!!! Replace one pin at a time !!!
and just to add, support the door during removal and assembly...
Re: door hinges
I just did this on an '85 S10; doors work like new. You *WILL* need a special tool to remove and replace the door springs. You can pry them out with a screw driver but no way in God's green Earth are you ever gonna get 'em back in. The tool is available online, doesn's cost much (less than $10) and makes the job very easy. Good luck and be careful with that door spring..... |
Re: door hinges
what springs? i dont see a spring
Re: Re: door hinges
Where might I find the spring tool. I've got a 2000 with the same sag issue.
Re: Re: Re: door hinges
http://www.etoolcart.com/browseprodu...r-GM-Cars.html This is the spring compressor you will need to make the job so much easier and it can be had for less than twenty bucks........... |
Re: Re: door hinges
Re: Re: door hinges
Re: Re: Re: Re: door hinges
Re: door hinges
as for the spring, probally not to safe but it worked for me. compress the spring a vise and tie it with safty wire in at least 3 places. slide spring into position and cut the wire and it pops into place. you might want to ware a face shield if your going to try this.
Re: Re: door hinges
I just replaced my pins (both front doors) stopped by my GM dealer and for 5$ a mechanic came right out side, compressed the springs and installed and I was on my way in about 5 min. I figured I would never use the tool again...good luck
