Old 01-12-2005, 01:03 AM
95grandprix64 95grandprix64 is offline
am i being ripped off?
I recently brought my car to a pontiac dealership for diagnostics because my 95 grand prix gtp isn't as powerful as it used to be. They told me that the distributor wires where badly corroded and that when they do that they also have to replace the ignition wires. does this sound right to anyone? I don't understand why the ignition wires would have to be replaced because the distributor wires need replaced. they also said that cylinder #2 isn't working. when i picked it up from them it was running 10 times worse than when i dropped it off. it was italing rough, making a strange clunking sound, exhaust making a strange sound also. I called them today and they said it was because of the distributor wires being badly deteriorated and when the mechanic checked the wires they just crumbled and they aren't getting a connection to plugs. and i need to get the car in as soon as possible to get it fixed because the injectors will get clogged and will cost me more in the long run. they want almost $500.00 to do the work. I need some good advice don't want to get ripped off.
Old 01-12-2005, 01:50 AM
Chazman Chazman is offline
Re: am i being ripped off?
Distributer wires - ignition wires ?? sounds like the same thing to me. Your car doesn't have a distributer.
Yes old wires could cause all of the symptoms, yes old wires break when removed.
Five hundred is out to lunch.
Haynes manual 25 - 30 dollars,
New wires from parts store 50 - 100.
Old 01-12-2005, 05:51 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Ditto!!!!!!
Old 01-12-2005, 10:16 PM
thank you!!!!! I thought that sounded pretty crazy. i might buy the wires and bring them to Monroe. The one i go to in Hamden is good. the guys are very nice and seem honest.
Old 01-12-2005, 10:24 PM
I just put $960 into it to replace the axle and transaxle, and the ball joint. is it just my car but i seem to be putting money into it every 5-6 months. I've had the car for 3 yrs and replaced the altinator, radiator, brake calipers and rotors 2 or 3 times, new head gasket 4 months ago, drivers side door handle etc. i'm not sure if i should put any more into it. cost me $5,000. and i think i put about $7,000-8,000 into since buying it. blue book values it at $2,1000 in good condition. i really like the car but it is becoming a money pit.
Old 01-13-2005, 08:08 AM
carnutcass's Avatar
carnutcass carnutcass is offline
Have you checked to see if you have a local chapter of ClubGP? I can't speak for all chapters, but the people in the St. Louis club help each other out all the time. This may be a good way for you to make some new friends, get some sound automotive advice, learn how to do some of these repairs yourself, get some help with repairs you can't do yourself, and SAVE A TON OF CASH.
I have fellow Grand Prixers at my house almost every weekend. This past weekend, I helped a guy install his FWI and Intense PCM, last week it was a radiator, a few weeks ago it was an F-body brake upgrade. Actually, most of the work I do to cars is to someone else's car, not mine.
Old 01-13-2005, 12:25 PM
Thanks i'll check into it.
Old 01-13-2005, 12:31 PM
ericvrose ericvrose is offline
The only time I would ever take mine to a dealer is if it were warranty work.
Old 01-14-2005, 04:22 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Ya That would be the only reason i go to a dealer is if it was warranty related or a recall--- other than its alot cheaper to do work personaly....
good luck
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 01-21-2005, 12:39 AM
I got the car fixed at Monroe. I saved over a hundred dollars. They charged me $350. including an oil change. The dealership wanted $468 w/o oil change. It was the plugs and wires. The reason why it was so expensive is because of the dohc. they had to tilt the engine to get at some of the plugs because they where near the firewall. Took them 4 hrs to do it. I like the guys there they are really friendly and seem to know what they are doing. I brought it back to them yesterday and they put in a battery that i bought. (which turned out to be the wrong size) They brought me to the store i got it at to exchange it for the right size. Very cool of them. they didn't have to do that for me. It was greatly appreciated and beyond the call of duty. I have had a lot of repairs done to my car by them. They didn't even charge me to place the battery in my car. If anyone lives near Hamden Connecticut i reccomend going to the Monro Muffler on Skiff St. The guys there are awsome.
Old 01-21-2005, 12:43 AM
carnutcass--I looked into Clubgp there aren't any in my area. Thanks for the suggestion though.
Old 01-21-2005, 12:50 AM
I don't know much about car repair and don't do any myself. Have to rely on a decent mechanic. Which i have found at Monro. If anyone can recomend anywhere else it would also be appreciated. They don't do all repairs. Thanks again everyone for your help. This site is awsome for advice. Everyone is very helpful.
Old 01-21-2005, 04:43 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: am i being ripped off?
I don't know about Clubgp. I live in Florida, and belong to this club in IL.
http://www.ilgpc.com/forum2/index.php?
The group has a bunch of nice guys. Try theirs.
Old 01-21-2005, 08:39 AM
carnutcass's Avatar
Not sure how close these guys are to you. http://www.macgp.com/
