Old 01-12-2005, 12:30 AM
novera6 novera6 is offline
Send a message via AIM to novera6
Question Grand am trun light cover issues
Hello
Frist ty at this. I cant figure out how to change the turn single light cover on the fornt of my grand am. I looked and can not finad any knid of screw. It almost looks like the bumper was put on over the turn single cover. Second question i am having a problem with my abs system. I know there is a thread on it somewhere in here but good luck finding it. Any way the abs light comes on stays on and will not turn off. Basicly i have no abs breaks. My car repair guy says not to worry about it. The car will stop. I have noticed it is the fornt left tire that seems to lock up any time i slam on the breaks or do something stupid. Is there maybe a bad speed sensor there or does it sound like a biger problem? Any help would be nice. Thank you in advance. Grand am, ok cars if you dont mind a few problems here and there.
Old 01-12-2005, 07:33 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: Grand am trun light cover issues
With regards to your ABS, check the fuse box. The fuse for the ABS might have been remove so it won't be operational. Some ABS fuse can be removed without ill effects on the brakes but you just don't have ABS function. Some ABS needs the fuse to fully function the brake system, otherwise you will not have a functioning brake.
You can try removing the battery terminals for 15 minutes or so and also remove the two front tires and remove and clean the ABS sensor. It will accumulate dirt and magnetic particles clinging to the ABS sensor. So clean the ABS sensor pretty good with some cloth to remove those magnetic particles.
Reconnect the battery and don't forget to check the ABS fuse and see if the ABS light is still ON.
