Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-11-2005, 11:05 PM
Mingish's Avatar
Mingish Mingish is offline
i need help fast
car failed emissions...all i have done is intake and exhaust...high flow cat..ever since i got the new cat, all i smell is eggs...it failed the "NO ppm"..i have no idea what that means
Old 01-12-2005, 01:21 AM
hontoy's Avatar
hontoy hontoy is offline
Banned
Re: i need help fast
YEP..HIGH FLOW CAT CAUSES HIGH NOX GAS....YOU NEED TO GET A BIGGER CAT TO PASS THE EMISSION TEST.
Old 01-12-2005, 04:50 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
use a gsr cat, instead of polluting the world with ur egg smells
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 01-13-2005, 07:40 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Yea a high flow cat will definately cause you to fail emissions.
1999 Eclipse Spyder GST-Race
-DSM Link,Injen Intake,Spearco FMIC,HKS SSQ B.O.V.,Apex TurboTimer,Greddy Evo Exh 3",660 injectors,Walbro 255 fuel pump,B&M Fuel Pressure Reg,Heads Ported & Polished,Momo Short Shifter Clutch Masters lightened Flywheel,C.M.Kevlar Clutch,Quaife LSD,Autometer Boost & A/F Gauge, EvoIII B16g Turbo,HKS 272/272 cams & HKS Cam Gears,Crower Valve Springs & Rods,Power Pulley Kit,100 shot Zex Nitrous
Old 01-13-2005, 10:23 PM
bingisSD's Avatar
bingisSD bingisSD is offline
Send a message via AIM to bingisSD
I hate to burst all of your bubbles and theres no need to trash talk me, but i have a friend that works at a 15 minute smog place, and he passed a car with headers and straight piping with a super rice muffler. the piping and backpressure has absolutely nothing to do with what goes on in the actual combustion chamber. I have no reason to make this up. I failed smog with my stock piping, (had him fake it) and then when i went to resmog it 6 months later after putting on 2.5 in piping, hi flow cat, dc 4-1 headers, and a super rice muffler BzzzzZzzZzZZ.
When you got your smog test the guys should have told you what to do to get it to pass.
Theres two types of testing places apparently you went to the test only. usually they will say oh you have too much co2 you need new sparkplugs.
the main determinant on passing smog is how youre engine is running overall, no leaks! do a tune up and put new spark plugs in the day you go to the place.
RESEARCH ' TIPS FOR PASSING SMOG ' youll see it has nothing to do with backpressure because they only test at low rpm's
www.cardomain.com/id/bingissd
http://www.automotiveforums.com/vbulletin/showthread.php?p=2660831#post2660831 <MEET IN DAYGO
Old 01-13-2005, 10:28 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
maybe thats how they do it where your from.. but im MA pressure does have a lot to do with passing. my civic has dual exhaust past the rear wheels and i brought it to my buddy who does the test and when he let it sit at idle, it read "exhaust dillution" (or exhaust leak) it uses the pressure in your pipe to determine if you have an exhaust leak, so obviously i would have about half of what i should, so he had to rev the crap outta my car to get it to pass.
Old 01-14-2005, 02:57 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Re: i need help fast
No vehicle will past a sniffer with a straight pipe on. that is a fact.
federal EPA standards are set for a light duty vehicle with 100,000 miles or 10 yrs old at .31 for NMHC, 4.2 for CO, 0.6 for NOx, .10 for PM. A new vehicle coming off the assembly line today will not meet this EPA standard without a cat. keep in mind, individual states have the same or higher standards. The day I legitimately pass a obd vehicle running a straight pipe will be the day mankind finds a new fuel to replace gasoline. That day is not even close yet.
Anyone can pass with a straight pipe if the price is right
tips fpr passing smog will not include running a straight pipe or hi flo cat.
your problem is not in the piping .
Ill help you re word yourself, everything before the cat has everything to do with emmissions the end result is what the sniffer finds after the cat.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-14-2005, 03:02 PM
AF - Advisor
get your stock cat back on.
Old 01-15-2005, 09:23 PM
5gcivic's Avatar
5gcivic 5gcivic is offline
Put your stock cat back on if you still have it, take it to get smogged and after you pass, that is if you do, put your high flow one back on until next year or when ever you have to smog it again. Kind of a pain but it will let you drive your damn car.
Old 01-15-2005, 10:37 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: Re: Re: i need help fast
i realize you guys are mostly talking about newer generation hondas but the stock motor in my 83 civic (1.5l CVCC) passed emissions twice with 2.25" straight pipe and no cat. now the 1.8l with the Webers...we'll have to see on that one.
my suggestion, change the PCV valve (cheep) and check your O2 sensor, if it’s bad it’s not so cheep but still not killer on the wallet
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
