Old 01-11-2005, 09:36 PM
jakes900 jakes900 is offline
torsion bar
I'm trying to level my truck out because my front is sagging a little. Couple of questions here. First haynes calls out a spec of no more than 1/4 clearence between torsion bar and support; when you tighten your torsion bar up does it shrink due to tension creating gap. Second mine is about a 5/8 gap is my torsion rod worn out? The adjuster bolt has about 1/4 of thread remaining.
Thanks
Old 01-11-2005, 10:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: torsion bar
Torque them in a bit more to bring up the front end up.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-11-2005, 11:33 PM
Re: torsion bar
Everyone I talk to tells me to replace the torsion bar mounts. how would that help me gain height? Also is it normal for the adjuster bolts to be very hard to turn. I am a pretty big guy and i'm putting a lot of force on them.
Old 01-11-2005, 11:51 PM
BlazerLT's Avatar
AF -Advisor
Re: torsion bar
What year is yours?
Old 01-12-2005, 01:30 AM
gearhead_v8 gearhead_v8 is offline
Did you jack up the front end first
Old 01-12-2005, 08:50 AM
Mikado14 Mikado14 is offline
Re: torsion bar
The only time I have ever adjusted the torsion arms is on my '93. The process can be tedious. The front end must be suspended off the ground while adjusting. The adjusting bolt is a square head. I used a Mitchell's Motor manual and it gives a height adjustment from a point on the frame to ground, it was 6.22 inches. Turning the adjuster in will give more height. After an adjustment is made, it is necessary to lower the vehicle and roll it so that the suspension will settle in. I'm sure you can see the tedious part of this.
The torsion mounts are important in that they mount the back part of the arm so that all movement will be on the A arm. If they are bad, you need to replace them first.
Old 01-12-2005, 12:31 PM
Re: Re: torsion bar
Originally Posted by BlazerLT
What year is yours?
I actually have a 1994 gmc jimmy 4x4 but their seems to be more info in the blazer section. I feel reallly stupid now, I just crawled under my truck and started cranking on the adjuster bolts. I can see how lifting the whole front end wounld make it EASY seeing as your not trying to lift your truck up by turning just one bolt. Do you think I hurt anything?
How do you know when the torsion bars are bad? Does anyone have any idea how many inches your height should change going from the bolt all the way out to all the way in?
thanks
Old 01-12-2005, 12:58 PM
BlazerLT's Avatar
AF -Advisor
Re: torsion bar
Hope you matched each side turn for turn.
Old 01-12-2005, 04:50 PM
Re: torsion bar
I leveled it by measuring from center of front hub to top of hood each side.
Old 01-12-2005, 10:37 PM
BlazerLT's Avatar
AF -Advisor
Re: torsion bar
No, you equally crank down each bolt the same amount of turns.
Old 01-13-2005, 06:08 AM
scholzee scholzee is offline
I have a plow on my 96 2dr and the front was sagging probably from carrying the extra weight in the winter time. I turned each Torsion adjuster 3 full turns and that raised my front 1" as measured from center cap of rim to fender lip. It sits nice and level now. Most torsion bar people I talk to will adjust them as they sag and not replace them until on breaks.
