oil problem with 1994 toyota
I posted some time ago with an oil problem with my toyota but I never reposted the fact that I had managed to solve the problem, For those that run into a similar problem, I solved it by drilling out the rivets in the baffles in the valve cover and cleaning out the sludge that had built up underneath them. I then drilled and tapped the valve covers and bolted the baffles back in and my problem was solved . The oil then quit being sucked out the pcv valve and fed back into the combustion chambers through the plennum. Hope this helps anybody with a similar problem.
Re: oil problem with 1994 toyota
Thanks for posting
DID YOU REPLACE YOUR PCV VALVE WITH A NEW ONE BEFORE YOU DID THE DRILLING THING? |
Yes, if you can trace back to my original post, I think it was under oil sludge prolems with Toyota camry, you'll see that I spent a lot of time and money chasing down my problem. This included changing valve stem seals and several pcv valves amongst many other things.
Thanks for the update. Its great to have members of the forum post how the problem was solved.
Thanks for the email. I just wish I knew how to post the solved problem along with the original question
