Old 01-11-2005, 07:52 PM
phoenity phoenity is offline
97 sunfire 2.2 slight miss sometimes and really bad fuel mileage
This summer the ignition module went out and the car sat in my garage for about 4 months. I just got the chance to replace it and it's running pretty well now. However there is still a very slight miss sometimes that I can feel when the car idles (the RPM never seem to flucuate) and it seems to be getting pretty bad mileage than what I remembered.
replaced recently:
AC Delco plugs
coils + module
TPS
before cat O2 sensor
fuel filter
oil + filter
cleaned IAC
new throttle cable (new one does feel a tiny bit looser than the old one requiring a bit more pedal effort, but I don't see how that could affect the idle)
Checked the plug wires for cracks, burns, and resistance seemed fine.
Last week two codes came up: one for the TPS low voltage and one for EGR stuck in closed position.
I unplugged the battery to let the computer reset for the new TPS and the EGR code has either gone away or not had the chance to come back on yet.
The car has never had an emissions test so I don't know if it's running rich.
Any suggestions for things I could check would be much appreciated.
Old 01-12-2005, 01:47 AM
noshun's Avatar
noshun noshun is offline
Re: 97 sunfire 2.2 slight miss sometimes and really bad fuel mileage
Can only see that the crank sensor would be at fault you've covered pretty much everything else!!!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-12-2005, 11:20 AM
Re: Re: 97 sunfire 2.2 slight miss sometimes and really bad fuel mileage
I'll check in my Haynes manual and see if I can test this. I would think a bad sensor would trigger a code, but hell it took weeks for the TPS to trigger a code!!
I was also thinking that a wire could be grounding...it is that slight. Any advice what I could do to check for this?
Edit: hell autozone has the CPS for only $8 bucks...might as well replace it and see what happens!
Old 01-12-2005, 02:21 PM
noshun's Avatar
You could try sprying all the connection with WD40 or similar (water disperant) and clean the connection at the starter motor. there is a ground for the ignition that bolts to one of the starter motor mounting bolts. Just some rough sandpaper to both surfaces.
