Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-11-2005, 07:35 PM
darbyhouse darbyhouse is offline
Unhappy 1998 Tahoe - Electricity but Dies - HELP
Ok, here's the problem.
Put key in ignition, turn vehicle on....interior lights come on, everything seems to be normal. Turn the key start the engine, all goes dark (with a few clicks from the starter first)....EVERYTHING. Remove key from ignition, close door, power resurfaces in vehicle, alarm goes off. Connected jumper cables to battery from another running vehicle. Tried again...same problem.
Is it the starter? Or a short somewhere? Loose connection on the starter?
ARGH. Any assistance or input would be greatly appreciated.
Frustrated in Houston (Galleria).
Thanks !!
Old 01-11-2005, 07:47 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: 1998 Tahoe - Electricity but Dies - HELP
Could be bad battery, altinator, or even battery cables.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-12-2005, 01:22 PM
txgearhead txgearhead is offline
I have had similiar happen to me, albeit in 2 different vehicles. The two culprits in my case, might be the same for you:
1) Bad Cell in Battery - Have it tested at Autozone or other
2) Corrosion on the battery cables at the point where the lead terminal wraps around the cable. I had no corrosion on the battery post, but had corrosion between the terminal and cable connection. The corrosion ate enough copper strands away to make the power cut when the engine vibrated.
Hopefully, #2 is your prob, it's really cheap to fix.
