Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-11-2005, 07:10 PM
cw290798 cw290798 is offline
93 rodeo electrical
I have gone through the usual bad alternater sequence, and thought to have fixed the problem. Now i have 14 volts when running, but brake, voltage, and gas lights all are still on, and my heater/ac blower doesn't work. What is there to do? bad ground maybe? If anyone has any ideas that would be excellent.
Old 01-12-2005, 12:00 PM
Tonupboy Tonupboy is offline
Send a message via AIM to Tonupboy
Re: 93 rodeo electrical
This just happened to me now...the Heater/AC blower stopped working, along with the battery light, brake light, and fuel light on my dash. Is this an indicator of bad alternator or something loose? Please help. drove me nuts at work during lunch today trying to check the fuse, relay - all which looked fine.....good thing I wasnt the only one.
_________________
T O N U P B O Y
"That which does not become a part of the one, shall become one with the void."
Allegiance: None
Function: Universal Dominator
2001 Nissan Pathfinder
1993 Isuzu Rodeo 4WD V6
Old 01-12-2005, 12:11 PM
amigo-2k amigo-2k is offline
Isuzu Guy
clean your grounds.
then have the battery load tested
then have the alt tested
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-12-2005, 12:58 PM
rodeo02 rodeo02 is offline
Did you verify 14VDC across the battery terminals with a quality volt/multi meter? (with truck running). The dash gauge is not accurate.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-12-2005, 03:52 PM
I called in NAPA Auto parts today to pick up a remanuf alternator. The voltage from the battery should be able to drive me home safely, but the heater doesnt work and its damn cold out (NJ weather) , and the battery, fuel, and brake light are annoying the crap out of me. Damn it, if its not one thing, its another with this old beater...lol
_________________
T O N U P B O Y
Allegiance: None
Old 01-12-2005, 04:07 PM
Re: Re: 93 rodeo electrical
Originally Posted by Tonupboy
I called in NAPA Auto parts today to pick up a remanuf alternator....
Oh boy... good luck with that!! I will admit, NAPA usually has top'o the line stuff when it comes to parts, including starters & alternators, but if this alternator is not 100%, which most remans are not, you will be in the same boat again real quick. I hate to keep saying it, and I've seen it happen COUNTLESS times now to 1993+ isuzu owners, but you have get a new alternator through isuzu if you want reliabilty.
G/luck
Joel
Old 01-12-2005, 04:20 PM
Re: Re: Re: 93 rodeo electrical
G/luck
Joel
I know dude, but those Isuzu ones are $$$! 500 bux is not cheap! Its 158 bux, so we'll see how long this alternator lasts. Wish me luck!
_________________
T O N U P B O Y
Allegiance: None
Old 01-12-2005, 04:42 PM
Re: Re: Re: Re: 93 rodeo electrical
I here ya. Until we can find a consistant source of reliable a/m high output alternators -or- whatever works, we are stuck. Who ever finds it will get a serious atta-boy!!! I dunno why, but the 'zu 3.2 with 4L30E tranny and all it's electronic wizzardry has to have steady, clean, constant currant or it's no-go .
G/luck
Joel
Old 01-12-2005, 05:37 PM
Update: As I was driving down the road, my problems went away! This happened twice today already. The heater blower started working again and the 3 lights on my dash (batt, fuel, brake) went away! WTF?? Loose wiring? Bad alternator still? Connectors messed up??? My truck is possessed!
_________________
T O N U P B O Y
Allegiance: None
Old 01-14-2005, 01:01 AM
MrMGA MrMGA is offline
I am having the Exact Same Problem as you and Tonupboy. I have replaced the alternator twice - once with a Pep Boys reman and a second time with one from the dealer. I have now spent about $600 on the problem and the brake, voltage, and gas lights still go on and off seemingly at random.
If anyone solves this problem, please let me know. Please!
Old 01-14-2005, 12:39 PM
sbrown2961 sbrown2961 is offline
Same problem with my '94
Anyone have a clear answer to what the problem was here? Same started with my '94 Passport yesterday; fuel, brake and battery light all on. Heater blower stops. Problem comes and goes when lights are on, heater blower stops.
Any help appreciated!
Old 01-14-2005, 01:04 PM
I was just PM'ing MrMGA that its possible that the wiring or grounding by the alternator is corroding up or loose...I was speaking from experience and since MGA bought 2 alternators with the same problem, I would check the wires and see if water might have corroded them...can anyone confirm this?
I haven't had a problem with mine so I saved money from buying a new alternator...
_________________
T O N U P B O Y
Allegiance: None
