Old 01-11-2005, 05:50 PM
Scarecrow.45 Scarecrow.45 is offline
2amps
i got 2 amps in my car. 1(lanzar) for 2-10" pioneers & 1(jensen) for 1-10" infinity. i blew tha infinity a few days ago so i took tha jensen amp out. i went & bought another speaker tha other day & went 2 hook up my jensen amp again but when i turned my stereo on tha lanzar amp wont turn on, it did hit tha ground terminal in tha trunk when i was hookin up my jensen amp, but all tha fuses r fine, ive checked all tha wirin but it still wont turn on. any ideas of whas wrong wit it/how 2 fix it?
Old 01-11-2005, 07:59 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: 2amps
I got an idea instead of mixing and matchin amps and subs sell the working stuff and get a new good system.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 01-11-2005, 09:43 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: 2amps
are you sure about the fuses in the actual amp? And did you check the fuse inline with your power wire. (the big fuse that should be about 12 inches away from your battery's positive terminal) If you touched your power wire to the ground, then theres a very good chance you blew a fuse, and maybe you just overlooked it.
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 01-15-2005, 04:21 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: 2amps
I 2nd that!
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
