Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-11-2005, 04:37 PM
ArnzCardz ArnzCardz is offline
Question Door pin
Hello everybody, thanks for answering my post about the oil lines. I have another question to ask. What kind of tools do I need to replace a door hinge pin? Where do I get tools? Is it a 2 man job or can I do it alone? Thanks in advance
Old 01-11-2005, 05:55 PM
96JimmySLE 96JimmySLE is offline
Re: Door pin
I have to do mine this week end, I'll let you know.
Old 02-25-2005, 03:21 AM
ourprecious6 ourprecious6 is offline
Re: Door pin
This is a 2 man job and you will need a hammer, a metal punch or phillips driver, and some patiences. This is a pain in the backside job. These doors are very heavy.
Old 02-27-2005, 08:33 AM
GMCTech GMCTech is offline
I do them by myself all the time. Just support well with a couple jack stands.
THe door doesn't have to get completely out of the way, just be sure to put a couple rags between the front fender and the door to keep the door feom getting scratched.
It make it a lot easier if you have the proper tools, but it can be done with a little inconvenience and normal tools (such as ourprecious6 listed above). A door hinge spring compressor would really help too.
Hope this helps.
Old 04-23-2005, 12:15 AM
kidaround79 kidaround79 is offline
Is it necessary to replace the pin if you really just want to change the hinge bushings?
I think i can grind the end of the pin off and weld it back with the new bushings installed...
is that a good plan??
Old 04-23-2005, 08:37 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Door pin
That's just ghetto.... A hinge and bushing kit is about 6 bux at the dealer... Why would you put a worn pin in with a new bushing?
