Old 01-11-2005, 12:39 PM
bored3917 bored3917 is offline
Send a message via AIM to bored3917
programing for keyless remote for 2000 firebird
Does anyone know the programing instructions for the 2000 firebird. Thank you if you do.
Old 01-11-2005, 01:38 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: programing for keyless remote for 2000 firebird
here are the instructions for most OBD2 Firebird keyeless entry systems but check your owners manual if these don't work for you. They always supply the instructions in there.
Programming procedure:
  1. Turn ignition switch to OFF position.
  2. Remove RADIO fuse 17 from fuse block.
  3. Cycle ignition switch from OFF to RUN three times within five seconds until the door locks and the hatch release cycle, indicating the Body Control Module is in the Programming Mode.
  4. Press and hold BOTH LOCK and UNLOCK buttons on remote control door lock transmitter for 16 seconds.
    1. Door locks will cycle once, confirming the transmitter code is programmed. The door locks must cycle completely to unlock before proceeding.
    2. Any transmitter code that was previously programmed has been erased.
    3. Body Control Module is now programmed to remote control door lock transmitter.
  5. When programming the Body Control Module to match remote control door lock transmitters, the first transmitter code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming the Body Control Module to match a second transmitter, repeat step 4. This must be done before the RADIO fuse 17 is reinstalled.
  6. Ignition switch to OFF.
  7. Reinstall RADIO fuse 17 to fuse block.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
