Old 01-11-2005, 03:29 AM
metroblue metroblue is offline
Question Metro will lurch, lope, surge, cutout on driving
I have a 97 GEO Metro w/ 57.000 k on it LSI automatic. I've only had it for 4 mos, paid very little for it because the windsheild was smashed ($850) But here's the prob: When driving sometimes will lurch, lope, surge, cut out, in that order, then all will be fine the next day. Or even later the same day. It'll start back up fine, but won't go. But later it will. I've read this entire board, and other people have has this ? but there was no answer, so I'm trying again. Shop has got it now, of course it did not act up for them! It's done it 3 times now, we are in winter now, so initially I threw some heat in it, but still doing it. Any thoughts? (I've read throttle sensor and timing could be..)
Old 01-11-2005, 01:36 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Metro will lurch, lope, surge, cutout on driving
if it turns out to be the computer i have one out of a 97 that had a 1.3 engine and automatic. you might also have shop check out the fuel pump. i had a 94 that did kinda what your describing and finally traced it to the fuel pump
Old 01-11-2005, 09:51 PM
geozukigti geozukigti is offline
Probably either the cam postition sensor or the crank postition sensor. If those give bad readings, your ignition timing will be off the map.
Old 01-11-2005, 09:53 PM
Re: Re: Metro will lurch, lope, surge, cutout on driving
Thanks, I'll keep that in mind- that's what I was thinking, too aboutthe fuel pump- thanks!
Old 01-11-2005, 09:56 PM
yeah, we'll see!
