Old 01-11-2005, 01:41 AM
sniper4x4 sniper4x4 is offline
Send a message via Yahoo to sniper4x4
NEED Help, A/C clutch siezed
On a 1990 Astro with a 4.3 is it possible to put a shorter serpentine belt on to bypass the compressor ? Tonight my clutch just siezed the A/C didn't work in the first place & it is just my work van I'm not interested in investing money into the A/C system if I don't need to. If I did this would I still be able to have a defroster ?
thanks in advance,
Ralph
Toys:
11' Camaro RS
99' GMC Suburban 10" lift
00' Mustang GT Conv.
07' High Jumper Sandrail (For Sale)
My favorite Toy 73 Kona 463 Olds
Old 01-11-2005, 02:08 AM
Re: NEED Help, A/C clutch siezed
Do any of you know if GM makes A/C delete brackets or are they only aftermarket add on item ?
Toys:
11' Camaro RS
Old 01-11-2005, 10:11 AM
blazee's Avatar
blazee blazee is offline
Problem?
Have you tried disconnecting the wires from the compressor? The clutch may not be seized, it be an electrical problem causing the clutch to engage in to a seized ac compressor.
If that isn't the problem.....
There should be a belt routing diagram on the fan shroud under the hood it will show if you can simply buy a belt to bypass the compressor if not, it is something the costumer must figure out.
Old 01-12-2005, 12:23 AM
How would I identify which A/C compressor I have ? Any suggestions
Toys:
11' Camaro RS
