Old 01-11-2005, 12:51 AM
str8Subbin str8Subbin is offline
Send a message via AIM to str8Subbin Send a message via MSN to str8Subbin
2 Batteries????
Is it possible to hook up my amp to a battery that my car isn't running off of. In other words can i have a battery just for my system
Old 01-11-2005, 12:59 AM
Picquerist Picquerist is offline
Send a message via AIM to Picquerist
run a power wire from the positive of one battery to the other...
the follow up with the "big 3"
just run your system off the other battery...
i believe you should be fine as long as its not for comp... i think there are rules about electrical upgrades of sorts
Old 01-11-2005, 02:10 AM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: 2 Batteries????
you need an isolator for the 2nd battery, or else one battery will just drain the other one
http://forum.sounddomain.com/ubb/ult...c;f=5;t=009326
thank link explains alot
Old 01-11-2005, 02:48 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: 2 Batteries????
i've done multiple battery setups I've never used an isolator and I've never had any problems
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 01-11-2005, 12:54 PM
Re: 2 Batteries????
that was my first actual response to a question that required a little bit of knowledge.
i would like to raise my hands at this time and jump around like a mad man
Old 01-12-2005, 06:34 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you can run parallel batteries, but it WON't do what he asked. You will have to use an isolator or diode setup or it won't isolate the primary battery from stereo battery.
Old 01-12-2005, 09:12 PM
Re: 2 Batteries????
hook them up you don't need the isolator I've done it multiple times.... as long as your not always running it w/ the car off you'll be fine
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
