Old 01-11-2005, 12:24 AM
beuthling beuthling is offline
Question Question ? (o/d off light) on all the time
My friend just baught a windstar 2001- the (o/d off) light is on at all times not blinking. Is this bad or good. every refrence i have read about has talked about a blinking light so sorry if this is a repeat.
Old 01-11-2005, 08:50 AM
DRW1000 DRW1000 is offline
Re: Question ? (o/d off light) on all the time
I think it just means that the o/d is switched off. I assume that the switch is not turning it on. I don't know the 01 set-up but on my 99 the button is on the end of gearshift lever and is a momentary pushbutton. Perahsp your switch is defective or there is a break in the wire somewhere and it just happened to break in the off mode.
You may have something more serious but check the simple things first.
Old 01-11-2005, 10:56 AM
lewisnc100 lewisnc100 is offline
Re: Re: Question ? (o/d off light) on all the time
Never heard of this since the computer resets the O/D back on when you restart the van, you wouldn't need to press the switch. But maybe a bad switch can override that reset. Is it off at all when the van is started?
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
2000 Windstar SEL
