Old 01-11-2005, 12:19 AM
Moliner Moliner is offline
Stock Boost
Hi im new to the forum and asking a question for a friend. What is the boost set at on a stock 1996 Eclipse GSX. Also does anyone have some good sites to buy aftermarket Eclipse stuff. Thanks...
Old 01-11-2005, 12:28 AM
1trickedoutdsmra 1trickedoutdsmra is offline
Send a message via AIM to 1trickedoutdsmra
Re: Stock Boost
research before you post
Old 01-11-2005, 12:35 AM
Re: Stock Boost
tried cant find anything....
Old 01-11-2005, 12:38 AM
george536's Avatar
george536 george536 is offline
Re: Stock Boost
10 to 12 i believe. Right now im stock running 10. because i have boost leaks some where just cant find them
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-11-2005, 12:57 AM
Re: Stock Boost
thanks george..
Old 01-11-2005, 07:44 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Stock Boost
This question gets asked once per week. But,
1g = spring pressure ~10 psi, stock boost 11-12 psi
2g = spring pressure ~7-8 psi, stock boost ~14 psi
It will vary from car to car, and even from boost guage to boost guage.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-11-2005, 08:24 AM
GSTRacerNVUS GSTRacerNVUS is offline
Re: Stock Boost
Did you happen to notice this sticky at the top of the page?
***FAQ*** Read this BEFORE you ask a question.
http://www.automotiveforums.com/vbul...d.php?t=213325
I'm sure you did, but you decided to ignore it. Try clicking on it and checking out all the info that it has on the page. See if you can find the vendors. Its much easier than "Where's Waldo", I promise.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
