K20A swap?
how difficult and expensive is it to do a K20A swap on a crx?
Re: K20A swap?
At least 6 grand if you do it yourself
If youve never swapped an engine before this might not be the best one to start off with. Also your going to need to do some custom fabrication to get everything right. www.hybrid-racing.com they have plenty of k-series swap information and since they havent come out with mounts or wiring harness for the crx if you do it yourself you might be able to strike a deal with them as a tester. If you have the money i say go for it. Youll have one fast as hell crx.
Here's to being single, seeing double, and sleeping triple
Re: K20A swap?
Use the damn search button, this is a topic atleast every week.
Re: Re: K20A swap?
![]() hybrid racing also sells a "swap kit" that retails for $3500; has all sorts of things that you would need to make the swap easy(but none for EF's yet): Mounts Header Axles Harness Golden eagle rail Fuel Lines Fuel Regulator Shifter Box AEM intake RSX Shifter cables Throttle cable Shifter linkage Clips EP3 belt EP3 Bracket w/pulley Thermo unit Throttle cable Switch Coolant Clutch Line Instructions |
