Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-10-2005, 11:31 PM
RedBeardMcG RedBeardMcG is offline
Send a message via AIM to RedBeardMcG
Low Engine Temp
I just bought a 97 Jimmy SLE, and have a concern with the engine temperature. I drove the truck for about half an hour, and the engine temp would not get above approx. 120 deg. The heat also never gets really warm. It warms the car, but just enough to be comfortable. My ex-girlfriend had a 96 blazer that did the exact same thing. Any advice on what the problem might be and how to fix it would be appreciated.
Ryan
Old 01-11-2005, 02:20 AM
J-Ray J-Ray is offline
Re: Low Engine Temp
Sounds like your thermostat is going out. Pretty inexpensive part...guessing between $15-25. Not sure where it'll be located...but the works at a garage shoudl run you $60 tops
Old 01-11-2005, 04:10 PM
spell spell is offline
Re: Low Engine Temp
Check your antifreeze to water level mix. Should be 50/50. Just as it prevents freezing, too much antifreeze will not let your car heat up properly. And of course too much water makes it get too hot. You can tell the difference when it is not mixed properly. You can get one of those coolant level testers for a few bucks at any auto store.
Old 01-13-2005, 08:48 AM
Re: Low Engine Temp
Thanks a lot... I'll replace the thermostat and check the antifreeze. Do you think it could also be the mechanical clutch fan staying engaged? Thanks
Old 01-14-2005, 12:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Low Engine Temp
Replace the thermostat and gett your cooling system and heater core flushed and filled with new coolant.
1995 Factory Blazer Service Manual for sale, PM if interested.
