Old 01-10-2005, 10:43 PM
Eric31 Eric31 is offline
Low fuel pressure
I have a 97 TA that has starting problems. It is only reading 20 psi of
fuel pressure. This should be higher, right? If so, would it be more likely
to have a regulator problem or pump problem?
Thanks!
Old 01-11-2005, 07:34 AM
CreepingDeath94 CreepingDeath94 is offline
Re: Low fuel pressure
It should be higher...I suspect it's the pump. The 85-94 firebirds had about 45 psi of fuel pressure and I don't see why they would have gone lower in the later years.
Old 01-11-2005, 01:46 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
How are you testing it ?. Is it running while you test it?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-11-2005, 10:38 PM
I tested it running and with just the key on. 20 psi is all
I can get out of it. BTW, the fuel pump is about a yr old,
I know how these aftermarket fuel pumps are. About a yr
seems to be all ya get.
Is there any way to test the regulator?
Old 01-12-2005, 11:40 PM
Update...I checked the pressure again and noticed that
after I shut the engine off and walked away for about 10
minutes the pressure had risen from 20 to 35 psi. Now I`m
thinking that the fuel filter is clogged?
