| Let's get Technical! Discussion for hardcore in-depth motor heads! |
b16 boggin
hey guys i got a question. I have a crx with a b16a swap and people say it should be faster then it is. I cant even beat my friends eclispe gt. It seems to bog out a lil bit at low rpms but it seems to be fine when i get on it. i took it to a buddys house and he checked the timing and it was on. He said it had something to do with burning oil in the valves. I dont know what is going on. Any suggestions? thanks
89 yellow crx b16 swap |
Could also be fuel related maybe fuel filter,injectors.
Re: b16 boggin
what do you run in the 1/4 mile ?
Re: b16 boggin
burning oil would usually cause blue smoke. have you tried checking o2 sensor? my d15 had a bad o2 sensor and runs like crap(even though i run it at 2000rpms city, you can hear it struggling even though my cousin's d15 hatch is heavier and can do the same thing with ease). also with the bad o2 sensor, my car was running rich.
Re: b16 boggin
try taking off youre intake cone, if its one of the mushroom tip ones and you push it on all the way it can restrict the hell out of you. then advance youre timing all the way, and then make sure that your check engine bulb wasnt taken out by doing the little check engine test. search the forum for the thread on how to check your check engine codes
a b16 hatch should easily take eclipses my b16 del sol would take gsx's, also if you know what vtec sounds like then listen for the different stages, listen to the change at 4500 rpm and the next one at like 6500. youll hear it go from zzzZzzzZzzzZzzzZ to zzZzZzZzZzZ to ZzZZzZzZzZZ
![]() www.cardomain.com/id/bingissd http://www.automotiveforums.com/vbulletin/showthread.php?p=2660831#post2660831 <MEET IN DAYGO |
Re: b16 boggin
thanks guys, i havent had time to bring it to the track , but i know the eclipce runs between 15.1-15.4 and he beat me by like 3 feet. i take a look at those things and see what happens
Re: Re: b16 boggin
SOUNDS LIKE THE PROBLEM IS THE DRIVER.. |
Re: b16 boggin
ya i guess so concidering i have like 5 people look at it and drive it and tell me somethings not right
Re: b16 boggin
dont let him get to you honda4u, hontoy is just a dumbass who is only borderline asshole, not enough to get banned. if Ricochet can get banned why not hontoy!
Re: b16 boggin
not sure if u noticed when u posted but hontoy was FINALLY banned.
