Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 01-10-2005, 09:07 PM
pro3racer pro3racer is offline
Speaker Size
I know this has been talked about somewhere, but my search yielded nothing. I have a 91 talon, the ESI, it does not have any special sound system from the factory. I blew out the rear speakers, and i need to know the size of them to replace them.
1991 Eagle Talon ESI, manual, 2.0 FWD
1992 Eagle Talon TSI, manual, 2.0 FWD
Old 01-10-2005, 09:30 PM
RSLaser RSLaser is offline
6x9, be careful, aftermarket speakers' magnets are bigger though! Itll take some modifying (LIKE MINE).
1991 Plymouth Laser RS
Only sat for a few years....
Old 01-10-2005, 09:44 PM
Are you sure, i'm not really good with audio, does 6X9 mean 6 diameter, width, or is it 6 inchs deep, or what? I have seen 6x9's and they are oval shaped, my rear speakers are circles, not oval at all.
Old 01-10-2005, 10:10 PM
6 wide, 9 long. Just search or go to a audio store and look for 6x9's itll be ok, if you need to know how to mod your mounting bracket in the car ill send you pics of my setup.
Old 01-11-2005, 05:10 PM
seriously, my rear speakers are circles, not ovals, so how can they be 6x9's The cover over the speaker is a 6X9, but the speaker itself is a circle.
Old 01-11-2005, 05:34 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Speaker Size
some came with 6x9's other didnt. i think teh round ones are 6 1/2. check crutchfield.com they have a what fits my car section that has all the sizes. i wouldnt buy from them though since they're really expensive
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-12-2005, 04:54 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Speaker Size
However, a lot of 6 1/2" Speakers will not fit, as the whole is actually larger that 6 1/2". be prepared to make an "adapter deally-o. as well, many speakers come with them so you put the speaker in it and then it will be larger. but i have owned two 1994 dsms and both were 6 1/2's. most are from what i know.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 01-12-2005, 05:42 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: Speaker Size
is it true that you have to remove the rear moldings and stuff to get to the speakers in a 2g that the grat doesnt just come off?
Old 01-12-2005, 09:15 PM
Re: Speaker Size
yup you need to pull the whole side moldings. there are clips along the bottom of the corner windows, along the bottom in between the side and the seat bottom (pull the seat, it makes it much easier. it clips on the front edge) theres also some clips in the middle that you just have to pop loose carefully. it sucks but its not as bad as doing a radio in a 2g
-1stGenRocks-
Old 01-17-2005, 07:14 PM
bighauns's Avatar
Re: Speaker Size
that is what I like about the 1G, easy easy easy radio. As for the rear speakers, I have seen guys just pull off some of the clips and just bend the panel and work very carefully. Has worked for them, for the most part.
One guy cracked the panel right in the middle, about a foot and a half long...NOT RESOMMENED
Old 01-17-2005, 07:55 PM
Re: Speaker Size
depends on what season it is lol. you can do it by bending the panel in the summer when it hot and flexible but forget about it when its cold.
-1stGenRocks-
Old 01-17-2005, 09:14 PM
I did it by putting a rubber flathead(just happened to have one laying around, obviously other soft tools will work), and began slowly prying around the edge, until every clip was done. Took me very little time. I'm getting my new speakers tomorrow, we'll see how it all goes.
Old 01-17-2005, 10:47 PM
GotGrip666's Avatar
Banned
Re: Speaker Size
well i allready have the seats out i guess ill see whats up when i wake up tomorrow
