Old 01-10-2005, 07:30 PM
aking3000gt aking3000gt is offline
Send a message via AIM to aking3000gt Send a message via Yahoo to aking3000gt
?!?!Problem?!?!
ok here is the deal.... im not sure the cause of this but .....
If your in neutral or driving and drive the car between 2500 and 3000rpm there is kinda like a clicking noise.... i can hear it better if im parked and rev in neutral b/c of course no wind noise..
i heard awhile back that someone thought they threw a rod b/c of the sound but it turnd out to be just his cluth.... im thinking my cluth doesnt have to many miles left on it so im hopeing that may be the problem..
ANY IDEAS???
1994 3000GT VR4 Pearl Yellow
1994 3000GT Base Pearl White
Check out my Cardomain Website!!!http://www.cardomain.com/memberpage/800196
Old 01-10-2005, 07:37 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: ?!?!Problem?!?!
how loud is the clicking? is it a click or a knock? and does it stay with engine RPM's or is it random?
Old 01-10-2005, 07:43 PM
Re: ?!?!Problem?!?!
its a loud click.... and can only hear it if you rev past 2500 rpm and you cant hear it if you stay above 3000 rpm
Old 01-10-2005, 07:46 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: ?!?!Problem?!?!
Its possible its an exhaust leak. But at the same time I have heard that knock is most prevalent at 3000 rpms.
Old 01-10-2005, 07:49 PM
Re: ?!?!Problem?!?!
i doubt its exhaust... b/c i just started hearing it
Old 01-10-2005, 08:25 PM
Stealthee's Avatar
Doesnt mean a thing. I thought I had rod knock because it all startyed at once. Turns out my egr pipe had a crack in it.
Old 01-10-2005, 09:27 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
my money is on lifter tick.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
