Old 01-10-2005, 06:48 PM
beuthling beuthling is offline
Talking Fixed charging problem
The problem is is that the red/ and green wire running from the alternater to the (T)15amp fuse.this wire goes to the alternater. He just cut the old wire out from the fuse box in the engine compartment. And ran a wire from there strait to the alternater. 69.00 later
- he said that the wire wase getting 2.5 volts but little amps so when I started there wasent anough ohms to push thru the volts (something like that)- so the wire was probibly burnt or coroded along the way!
anyways thaught you should no -thanks
