Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-10-2005, 04:36 PM
serpent_1977 serpent_1977 is offline
Computer problems....
Well, after much searching and replacing, we have come to the conclusion that somehting has shorted out on my computer. Does anyone know where I can get another one? I replaced the injector to find out that nothing was wrong with the old one, the computer was not grounding it. We traced the ground wire to the computer, and found out that nothing is wrong with it, the computer is just not grounding it.
Old 01-10-2005, 11:37 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Computer problems....
http://internetautomart.com/
junkyard
btw. one, six inj dead?
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-11-2005, 07:21 AM
It is only one injector, the #2 injector is not firing. We have checked everything, but it all points to the ground. We found the ground at the computer, and we jumped the ground wire straight from the injector to the computer, so we know nothing is wrong or shorted in the wire.
Old 01-11-2005, 01:45 PM
There's click to be heard when:
- ECU gives pulse
- coil is ok
- gnd is ok
- harness is ok
- injector needle works.
Is there?
If u mix injectors 2&3 wires, any change in the "click"? If the dead one 'moves' to #3, problem is coming from ECU.
Have u cleaned ECU connectors?
Screwdriver on the injector, ear on its handle =stethoscope
Old 01-11-2005, 02:03 PM
infinman infinman is offline
Given that a fuel injector pulses {grounds on then off} once every 5.0 milliseconds during cold start, how are you checking injector grounding?DONOT short injector wire to ground at ECM or injector driver damage will ocurr.
Old 01-11-2005, 02:11 PM
I checked all of that, and when I switched the plug to another injector, then that one went dead instead of the other one, that is how we came to the conclusion it was somewhere in the computer.
Old 01-11-2005, 11:03 PM
Still one question: does ECU receive full 12V?
That means: has main gnd point been serviced, ECU relay contacts cleaned? If ECU is starved (well always lives on the edge, does not need much to tumble doen) it will do any thing.
Scenario: If ECU pwr supply was gradually starved, voltage goin' down, then at one stage first one component would stop working, after that another an so on... In this case one of the injector solenoid drivers (FETs, Thyristors whatever).
Get fresh gnd & +12V wires from battery to ECU just to tst. If problem still persist, time for swap.
