Old 01-10-2005, 03:21 PM
Maxima Lover Maxima Lover is offline
Send a message via AIM to Maxima Lover Send a message via Yahoo to Maxima Lover
Question please help, question!!!!
I want to know the differences in the engine between the 1990 and 1993 as far as engien specs/parts/problems go for the Eclipse GSX. my brother is looking into getting one for strictly autocross and possibly rally and wanted to get an evo, until a guy who owns an evo and is close friends with him explained to him that the car sucks on rally and that you need to mod everything. so now hes all into getting a 1st gen dsm. i told him to get a lazer or TSi but he bitchs that the car is domestic and im like, it says mitsubishi on the valve cover, but whatever. So yea the only reason im asking is because someone told me that between 90-93 and 94+ they used different cam gears or something?! and i just want to know basically. Between 1990-1993 differences in engine parts/specs/known issues with car and then 1st Gen compared to 2nd gen. i appreciate it guys. thanks
Old 01-10-2005, 03:50 PM
macder macder is offline
Send a message via MSN to macder
Re: please help, question!!!!
1990 - 1992 uses the 6-bolt 4g63, 1993 - 1999 uses the 7-bolt 4g63. There are very minimal differences between both generations except that in 2g's the 4g63 motor was replaced by the 420a(Chrysler) for the non-turbo models
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 01-10-2005, 04:01 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
the 1st gen talon/laser/eclipse were on made on the same factory line...there is no reason why he should choose an eclipse or talon or laser awd turbo's over each other..except for the condition and price of them...they are all the same when you compare model type for model type.
consider them all one car...find the best price/condition
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 01-10-2005, 04:29 PM
and whats the diff between 6 bolt and 7 bolt?!
Old 01-10-2005, 04:31 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
search! everything you've asked so far has been discussed before and hasnt changed since then.
in short a 6 bolt is slightly more reliable and can create more power.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
