Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-10-2005, 03:47 PM
PimpedEclipse96 PimpedEclipse96 is offline
Clutch Problem
Hello,
I have a 96 eclipse spyder gst and just the other day the clutch lost all pressure and just stuck to the ground. I filled up the tank and all was well, but then again in another couple of miles it started to loose pressure again. I have looked at the res. tank yet do not see any leaks between the tank and were it goes into the firewall. I cant follow were it goes after the firewall, does anybody know where it could be leaking? There are no spots under the car.
Thank you in advance
Old 01-10-2005, 08:14 PM
Re: Clutch Problem
Just wondering if anybody can tell me how and where to bleed the clutch? Thanks!
Old 01-13-2005, 03:08 AM
BrentCosenza BrentCosenza is offline
Send a message via MSN to BrentCosenza Send a message via Yahoo to BrentCosenza
should be a bleeder valve at the front of the motor right behind the mount on the bottomlook and you'll find it....
BRENT COSENZA
1997 EAGLE TALON 5 SPD
1998 DODGE RAM 1500 3.9L
1994 DODGE RAM 1500 5.2L
1997 DODGE NEON
1989 CHEVROLET CAMARO RS
Old 01-17-2005, 09:11 PM
skunky_2003 skunky_2003 is offline
Send a message via AIM to skunky_2003
Re: Clutch Problem
ok i have a 95 talon esi...mine is kinda doing the same thing especially at hight rpms and then when i shift it loses pressure and then comes back really weak and progressively worse....then i go and bleed it and it fixes it until i get the rpms up there...then i have to refill everything then bleed it and all...i was told my clutch slave cylander was messed up but i dint think it was i thought it was the master because it wouldnt pump up for noting but i took it out and its fine pumps like a champ (right into my eye) so i guess it is my slave cylander cuz all my lines r dry...any comments???
Old 05-29-2005, 01:09 PM
talonman9009 talonman9009 is offline
Re: Clutch Problem
i put a new slave cylinder on my 1990 and bled it like 50 times and still not very good pressure any ideas guys
